911 SC head recondition question
After chatting with my friendly machine shop tech concerning the reconditioning of my heads, he suggested using firmer springs from Jerry Woods Enterprises. These springs offer protection from a possible over rev not exceeding 9000 rpm or there abouts.
Has anyone gone this direction? His advice seems acceptable to me. There would be an additional charge of around $300.00 which I would gladly pay for a bit of additional insurance to protect my engine from the novice driver of the car( Me!). Any advice or stories would be appreciated! |
Senior Member
Yep, it's common for folks to install stiffer springs. If I did that, I'd also want to use Ti retainers.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
Building a race engine?
If not, stock springs are perfectly good, sez the pro who re & re'd my 3.0 heads.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Author of "101 Projects"
Dougs right - stock is fine if you're not going to 8000K red line...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
It will put more pressure on the cam geometry and associated parts.
2001 Turbo |
Irrationally exuberant
For the street where you never miss a shift, stock is fine.
For the track, where um "accidents" do happen, stiffer valve springs and light weight retainers make a missed shift an "ooops" vs a bunch of bent valves and a trailer ride home. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks Chris! I will track the car in DE events. I know I will miss shifts while learning. I've already had to trailor the car back home once due to mech failue. With more track time scheduled, I'd like to have a bit of insurance.
In time, I want to race PCA. My goal is to build that car in a couple of years! This rebuild, is meant to get me back on the road for pure Porsche driving pleasure and to learn more on the track!
1980 911SC One day will be "G" Stock PCA racer |
Another option is to get new stock springs. I'm told they get weak over time. When I rebuilt my engine I found a mark from the intake valve on top of 2 pistons. Although I'm not racing now, I approach 6k often enough to want to make sure. I replaced my springs and valves.
$108 here on pelican for new springs. 1/3 of the cost of the race ones. Just another option / opinion. What are you doing about rod bolts?
Bill Miller 81 Targa Guards Red 3.6, M&K 1 out, S4 brakes 83 ROW CAB Rubinrot Metallic (RIP) |
William, I will use stock rod bolts. I feel that going with ARP or Raceware would be over kill for this re-build. If adding race type springs will create addition stresses on other components I may be causing problems else where. I wonder if I use the Jerry Woods springs valve springs, which components I would have to consider upgrading?
-Chris
