Slumlord
Porsche_monkey's Avatar
Yes John wins. Dirko rules, huh?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-30-2004, 04:44 AM
Porschephd's Avatar
Not that I have had any issues with 574 (hope I never do) but I have a rule of thumb. I set all my bearings, check all the orings, dowels, etc and regroup. I then apply my 574 when I am ready to put the case halves together-NOW. I never let them sit longer then smearing the 574 with my finger and slapping them together. I do see guys having issues with them when they let sit, even for 10-15 minutes. While it is not supposed to make a difference, I believe you can not let it skin. At any rate I just make sure it is a smear and go.
Stephen
94 3.6Turbo 6-speed AWD
Old 04-30-2004, 08:24 PM
Author of "101 Projects"
Wayne 962's Avatar
Don't know if I buy that. The 574 shouldn't harden - only in the absence of air. Theoretically. I've seen squeeze-out that never hardens. Still 45 minutes tops is what everyone seems to use as the benchmark for assembling the case halves...
-Wayne
Old 05-02-2004, 09:54 PM
dtw dtw is offline
GAFB
It skins like gravy if you don't assemble it quickly. Good to have all components ready to go as soon as the orange goop is spread. It doesn't harden up, it just skins.
Several BMWs
Old 05-02-2004, 10:07 PM
Porschephd's Avatar
In theory it should not dry until it is without air, however I have heard of way to many people having issues with letting the 574 sit. I can say that I have seen it skin when blobbed on the surface and left. I believe it is the skinning in conjunction with the amount. If used with a roller I doubt there to be an issue, however with a smear and glob from your finger the amount is far greater and one small spot would cause a mess. There are a few examples on this board as well as John. For me, I can't risk it. Not with the warranty I offer. 574 and put that case together.
Stephen
Old 05-02-2004, 10:10 PM
Irrationally exuberant
ChrisBennet's Avatar
Steve Weiner told me that the trick is to snug down the perimeter bolts first. I see Greg Brown also says the same thing. Greg Brown wrote a good article (does he write any other kind?) about case sealing in Velocity Winter 2002 starting on page 24*. Thanks to Bill V. for tipping me off to this article.
-Chris
* Page 24 of the PDF, page 46 in the hard copy magazine.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-03-2004, 07:02 AM
Porschephd's Avatar
That is always a great idea and I do agree. The ONLY time I DON'T is when it is an old 2.7 case.
Stephen
Old 05-03-2004, 07:05 AM
Wayne 962's Avatar
This is another topic up for interpretation. On the subject of 574, I think that it gets blamed quite often as a material defect, when in fact, the problems are with long install times and/or poor surface preparation. I know that on at least one motor, I was guilty of not preping the surface well enough, and it did begin to leak there.
As for tightening the bolts - Stephen has it right - the early mag cases are a problem, and tweak and torque themselves. I would say on the aluminum cases (stiff) that it wouldn't terribly matter which order you torqued the nuts down, but on the mag cases (especially ones that haven't been machined fully/properly), I would torque down the through bolts first...
-Wayne
Old 05-03-2004, 10:19 AM
Nitrometano's Avatar
May the engine need a Kotex!!!
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-24-2004, 09:20 PM
As a quick update, I've got the engine case, all sealed up and just getting ready to install the exhaust and intake? Might actually be able to get it in the car over the holiday (July 4th) and see if I did a better job this time round.
As for cleaning the cases, I was meticulous this time round. Made sure ti really wipe everthing down and applied plenty of 574. Reinspected the case (with another set of eyes examining and found a piece of the spreader brush). Did a double examination of the case to make sure it would go together cleanly, then put it all together and tightened it down quickly and efficiently (that's what I think I did wrong the first time round).
In case your wondering why it's taken so long, I have a two year old (who likes to help) and a 4 month old (and a wife that puts up with my obsession).
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 06-25-2004, 07:00 AM
Slumlord
My suggestion is to use plastic spreaders from a hobby shop, not the cheesy little brushes that leave hairs behind.
84 Cab - sold!
Old 06-27-2004, 03:27 PM
Update: She's Alive, alive I tell you, alive.
Fired her up this weekend. After about 10 seconds of cranking, she fired right up. Idle went to about 1800 then settled down to around 1000 RPMs. Talk about a relief.
And then, I notice a leak. I'm thinking, oh *&$%. Went back and looked at where it was coming from and thought, well that's strange, it's coming out of the passenger side heads. That can't be right.
Walked away, and then came back. Looked closer, and noticed that it was coming out of the oil fitting on the chain tensioner on the passenger side. I remembered that in Wayne's book, he mentions not to over tighten since you can always tighten if they are leaking. Picked up the wrench, gave it a little snug, no more oil. When it was leaking, it fell down on the metal surround and leaked everywhere through it. Now, it appears that I have a leak proof engine.
Talk about relief.
Then I noticed the fuel leak. The rubber line running from the engine to the hard line that I believe runs back to the tank was leaking. Reached in there, tightened it up, still leaks. Tightened it up a little more, still leaks. So, I'm thinking that a 22 year old line has the right to leak and I'm not going to question it (I think the fitting on the inside is turning as I turn the nut on the hard line).
Any way, It would appear that the reason why the engine leaked the first time was that I didn't get the cases put together quickly enough.
Many thanks to a lot of members of the board.
Wayne: Your book is excellent. Had I followed your advice without question, I probably would have not had to do it twice.
Others: Thank you for your advice, your tools, your opinions, and your support. This was something that I always wanted to do and am much richer (poorer actually) for the experience. Of course, I'm already thinking a couple years down the road when I build my race car. Going to wait till my kids get a little older so that they can be involved.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-19-2004, 07:35 AM
Congrats on your engine rebuild. I might suggest that you use a 2nd wrench to counter hold when tightening any sort of fitting.
-Chris
Old 07-19-2004, 08:11 AM
There's no way to counterhold on that line. Not that I know of. It's called the fuel return line. It's a rubber hose that doesn't have a nut to hold onto. It's hard for me to explain. I can put my hand on the line and it doesn't turn when I turn the nut on the hard line that connects to it, but I can't get it to stop leaking.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-19-2004, 08:27 AM
use a 11mm open end wrench to counter-hold the return line. there are flat sides on the metal end that attaches to the engine line.
206 637 4071
Old 07-19-2004, 10:11 AM
John,
You are the man. Worked like a charm. Took a little less than 1/8 turn to seal it. No gas leaks. Took my car for it's first spin. I purchased it in boxes so this was the first time I've ever driven it.
Thank you to you, Wayne, Henry, Grady, and quite a few others for all your advice.
I'm having a good day.
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-19-2004, 09:33 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally posted by snowman
If this were a chevy you wouldn't have this problem.
That's right. "if it were a Chevy you wouldn't have this problem". But then again if it was a frog you wouldn't have to feed it gasoline. My point, a frog is not a car and a Chevy is not a Porsche. I would rather eat sand than give up my Porsche to drive a Chevy, any Chevy.
That said, I do own a Corvette but if I had to choose, the Vette is gone.
Back to the real question: We always use 5 different adhesives when assembling 911 engines.No one adhesive can perform all the needed sealing requirements. ThreeBond 1104 on case halves, ThreeBond 1211 on the # 8 main bearing, Curil T on the cylinder base geskets, 574 Loctite where the case halve comes together at the through bolts and on gaskets (very this coat) and Epoxy patch where epoxy is required.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-25-2004, 09:09 AM
Send a message via AIM to 82SC
this may be a dumb question but could someone, post rebuild use the case breather hose and pressurize the case to see if there are any obvious leaks?
Problems with this that immediately come to mind is that the case is not heated so it may not reveal all leaks
I guess one would have to plug up all oil lines...and I would guess that leaks by the cylinders would be minimal...
hmmmmmmmmmmmm
Old 07-27-2004, 11:30 AM
anyone...
Old 08-03-2004, 03:03 PM
hmmmmmmmmmmmm
I've thought of this question for a while and haven't come up with a good answer. Seems like it would work. My question though is oil is made to move in a particular direction inside the engine. If you just presurized the engine, what damage could you do to some of the relief values internal to the engine. Probably nothing but I dont' know. Some of the experts would have to chime in. Had I built the engine right the first time, I wouldn't have had the problem.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 09-08-2004, 01:44 PM
