Hi everyone,
Returned to the garage today for the first time since before Christmas. Temps have been too low in there. Last time in there, I had just completed my engine rebuild to the point prior to setting the cam timing. Today, I intended to finish that task, mount the hydraulic tensioners and assemble the cam rockers. Cam timing took longer than I expected, but eventually managed to get it spot on. I then bled the LHS tensioner and mounted it. It was then I noticed a gap between the tensioner and the chain idler body. I wasn't expecting there to be any gap. My car is an 83 SC, and it had the hydraulic tensioners fitted by the PO within the last 10k miles. I am reusing the tensioner and idler gear. Everything else in that area is new. I was careful to keep all the parts together during disassembly, and I can't find any shim or spacer to make-up the gap. I measured the gap at about 0.09" and I am wondering if this is normal? According to Wayne's book, my car shouldn't need the spacer, and it looks like I have the later idler gear. That spacer in the book also looks thicker than 0.09" Image attached to explain what I mean...The gap can be seen between the outer edge of the idler collar and the inner edge of the tensioner body where they share a pivot shaft... Thanks, Mark Bradbury 1983 911SC 3.0L (soon to be a 3.2L short stroke) |
I don't think that gap is bad. I know there is a little gap there normally 'cause I use it to pry the tensioner off the shaft. The idler has to be free to move a little so it follows the chain right? Hopefully a pro will jump in here and confirm.
BTW: Don't forget the O-ring on that tensioner. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i Coupe http://members.rennlist.org/messinwith911s/ |
CEO, Pelican Parts Inc.
A small gap like that is normal...
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman Coming in 2012: • 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997 |
HI,
Thanks Chris & Wayne. I went ahead and moved on to closing the rest of the engine. Thanks Mark |
