Now in 993 land ...
964 cam in 81 US 3.0
I am playing with the idea of putting 964 cams in place of the SC cams. Actually welding and regrinding my cams to 964 profile.
1. Will I have any valve to piston clearance problems with the stock 81 US pistons (CR: 9.3:1)? 2. Will I be fine with the stock SC valve springs using the 964 cam? I have no time to take the heads off or do anything else that 's more involved. Please let me know if I can do this without valve to piston clearance problems, before I haul the bumpsticks off to the cam grinder! ![]() Thanks! George |
drag racing the short bus
I think Jim (Superman) did the same mod as what you're thinking of. He used 20/21s, which are a bit more radical than 964 cams. If memory serves me, he has a stock valvetrain, so if 20/21s will be fine, 964s should work, too.
911 valvetrains are fairly substantial. They can withstand 7,000 + RPMs. You won't rev that high with your engine unless you miss a shift. ...so don't miss a shift.
The Terror of Tiny Town |
You might want to get your rockers reconditioned (or new ones). That's what was suggested to me when I was thinking about it. I didn't end up doing it because I wasn't sure what it would do to emissions. I heard conflicting advice so I went conservative.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
I got new rockers after my regrinds. I've always heard it was essential since the cam and rockers must bed together on their hardend surfaces. Worn rockers have less of a hardend surface since they are already worn to the old cam profile.
Lee 78sc Elgin 330 cis cams (cheater cam) New Stock Mahle cis pistons 8.5:1 Boat tailed webs. Much more fun to drive now.
78SC coupe, Silver Metallic |
Now in 993 land ...
I'll get new ones. I learned that you would want new bushings too, if you have them refurbished. The cost will be similar to just getting new ones.
EBS says I should have no clearance problems with the 964 cam. Of course I will check, but want to make sure that I am 99% confident. Would shuck to have the 964 grind ground down again to the SC for clearance reasons. ![]() Thanks, George |
You need to reset that value spring sims to get the correct valve spring height for the cams. Otherwise you risk coil bind if you ever miss a shift or slightly over rev the motor.
Tinker |
Now in 993 land ...
Uh-oh, now it is getting interesting. I am not prepared for that. Better go check out the lift difference betwen the 964 and the SC cam. Thanks for the pointer!
George |
Now in 993 land ...
3.0 CIS cam grinds, 964 vs. web 20/21
According to this thread I am looking at about 200 and 600 micron of lift difference on the intake and exhaust side between the SC and the 964 grind. I doubt that this will present a problem. What do you guys think? George |
