While I'm at it - tranny?
Pulled the engine for a top end. Should I do anything to the '82 915 besides a clutch and flywheel?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 03-22-2004, 03:34 PM
Irrationally exuberant
ChrisBennet's Avatar
It gets expensive real quick...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-22-2004, 04:06 PM
What does?
Old 03-22-2004, 06:13 PM
Originally posted by markwemple
What does?
Rebuilding the transmission. The last few years transmission parts prices have doubled or tripled.
-Chris
Old 03-22-2004, 06:34 PM
Doug E's Avatar
Ummm, having just gone through this myself here some things to consider :
Pressure plate
Throw-Out bearing
Guide tube
Release fork
Helper spring
Clutch cable
BTW, I had my flywheel resurfaced by a local shop for something like $50 so depending on the condition of yours you might want to consider that.
Doug
'81 SC Coupe
Old 03-22-2004, 06:36 PM
the trans parts should be around $900 if you DIY. that wouldn't include clutch related stuff.
206 637 4071
Old 03-22-2004, 06:52 PM
Doing the clutch disk, pp, t/o bearing, flywheel and cable. Why the fork and tube? Are there any seals that are good to do?
Damomma's Avatar
Guide tube is now $125, turn it over if it's not too bad. Will yours shift into 1st when you are moving?
78SC Porsche Targa, 71 911T
86 Mazda RX-7 ITS SCCA racer
05 Porsche Cayenne
05 F350 Powerstroke
90 Miata
Old 03-22-2004, 07:26 PM
Yup. No problem shifting but, then again, I was trained to shift into 2nd before going into 1st to slow down the syncros.
Old 03-22-2004, 08:15 PM
FYI the trans works fine. I am a big fan of preventive maintenance and wanted to know what fails regularly that would be good to replace.
Old 03-22-2004, 08:18 PM
If you aren't going to open the transmission I'd:
- check the seals for leaks
- clean and relube the clutch fork shaft
- probably replace the funny seal(s) on the above shaft, they get crumbly
- check the guide tube for scoring (clean and relube w/moly grease)
-Chris
Old 03-23-2004, 04:39 AM
Damomma's Avatar
markwemple, sorry for the newbie question but when you say "I was trained to shift into 2nd before going into 1st to slow down the syncros" how do you actually do that? If you are already in 2nd do you come out of 2nd to neutral than back into 2nd then go for 1st?
05 Porsche Cayenne
05 F350 Powerstroke
90 Miata
Old 03-23-2004, 05:27 AM
If I'm in second I shift into first with the short delay that all 911 drivers are supposed to use, the neutral position wait (the reason we all shift slowly). I never do it with high revs though as I only use 1st at a light or driveway or such.
Old 03-23-2004, 06:07 AM
Rob Channell's Avatar
I'd want to put in a Quaife, but I'm sorry I don't have an extra one of those for you.
Rob
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 03-30-2004, 07:46 PM
Me too but the budget doesn't come close to having $ for that
Old 03-30-2004, 07:59 PM
oneblueyedog's Avatar
Resurface Flywheel!
Replace clutch,PP and TO bearing, pilot bearing, FWheel Bolts.
Drain fluid
Get all seals and replace them-including guide tube and shift rod seal in front.
Clean everything. (just as hard to do as a case cleaning)
There's some kind of shifter fork acess plate held on with 4 nuts. On it is some kind of fork held on with 10mm nuts and lock washers. The lockwashers were broken and the studs that held the fork were stripped and the fork was loose. I replaced the worn parts and gasket. A good catch.
Replace the back cover gasket if leaking. I used Drei Bond and the gasket.
Replace all CV joint fasteners with exact like kind. Get some Schnorr washers for all the fasteners and use them.
Replace CV boots after you clean and repack the CV joints.
Use new CV joint gaskets.
Get a clutch cable boot if you need one.
Fill it with Swepco.
That's what I did so I wouldn't have to bother with it for a while (hopefully +5 years).
Hope it helps.
Lee78SC
Old 03-31-2004, 06:54 AM
The clutch cable boot, are you referring to the one on the body or the cable? If the one on the cable is replacable please let me know as there are signs of wear but the cable is fine as far as I can tell. Thanks.
Old 03-31-2004, 07:22 AM
It's the one on the cable end that helps keep grit out. If the one in the body is shot (mine was at one time) replace it. It helped keep engine fumes out of the center tunnel, and dirt. If I remember right the center tunnel is some sort of feed fro the AC evaporator. It got rid of the gear oil smell before I rebuilt the drivetrain.
I did not have to replace the clutch cable. I replaced the boot because the original was rotten. Use some silicone lube to help slip it over the end hardware.
78SC coupe, Silver Metallic
Old 03-31-2004, 07:19 PM
I looked on pelican but couldn't find it. Any suggestions on where to purchase it?
Old 03-31-2004, 08:06 PM
311-713-269A $6.00 Via Pelican. It was under Cables.
Old 04-01-2004, 01:08 PM
