How to test Engine Oil Cooler Thermostat?
Hi,
Wayne's book said to put it on a hot plate & make sure it opens. How could I tell if it did open? Am I supposed to hear or see some moving parts? I tried the method & the whole unit is so hot that I need the oven mitts but didn't notice any changes. Thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
GAFB
I test them by sticking it in a saucepan full of fresh oil. That way, I can hold a thermometer in the oil and see the temperature when the thermostat opens. Either way, you'll see the thermostat slide open when it heats up.
Several BMWs |
Thanks Dave...
Tried your suggested method & the thermostat does indeed slides. The triggering temp seems to be around 185F - does it sound right? thanks.
I used water. I found mine to be bad. Yours sounds like it is good. It think the opening temp is stamped on the unit.
Mine did not open at all.
78SC coupe, Silver Metallic |
GAFB
185F sounds spot-on.
Several BMWs |
Thanks guys...
Now that I have the peace of mind, its going back in with a new seal
