Cleaning Loctite from Case
What is the best way to clean Loctite from the Case Halves? I've been using the scraper but I'm afraid of getting to aggressive. Is their a chemical I can apply that will assist?
All responses appreciated.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 04-05-2004, 08:54 AM
Did you try acetone?
Arnie
Old 04-05-2004, 09:10 AM
Send a message via Yahoo to Groovy911SC
Brake cleaner used in generous amounts seemed to work the loctite off.
1980 911SC
One day will be "G" Stock PCA racer
Old 04-05-2004, 02:01 PM
Super Moderator
cstreit's Avatar
If you use a scraper or razor blade, pull it rather than push it, this will keep it from digging in to the material.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-05-2004, 08:20 PM
i use a semi-sharp pocket knife, and shave it off.
206 637 4071
Old 04-06-2004, 09:01 AM
Irrationally exuberant
ChrisBennet's Avatar
I use a razor. Scape in the direction of the joint so if you do make a scratch, it won't make a path for oil to travel from inside the joint to outside.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-06-2004, 12:54 PM
Thank you all for your thoughts. I'm going to try the brake cleaner on it to start, then move up to Accetone if that doesn't work well enough. The thoughts on scraping backwards and away from the joint are really good tips.
Thank you all.
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 04-06-2004, 01:31 PM
Senior Member
Doug Zielke's Avatar
I used a heat gun to soften it up a bit. Then, a (dull) gasket scraper and some lacquer thinner to finish it off.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-07-2004, 08:13 AM
Who is John Galt?
Rondinone's Avatar
I found that acetone and a scotch brite made short work of the loctite.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 04-07-2004, 04:32 PM
frog's Avatar
I have the same problem. I put a bolt which was covered with old loctite into acetone for a week; no reaction.
I heard epichlorohydrin is a better solvent than acetone but I have no experience with it.
Has anybody out there used this stuff before ? Did it work ? What precations did you take ?
Old 02-27-2005, 05:27 AM
I don't know why I didn't mention this before, maybe I discovered it since I last posted to this thread. Loctite/Permatex 80646 Gasket Remover will take it off. It will also take the paint off your engine
stand so be careful where you spray it...
-Chris
Old 02-27-2005, 06:17 AM
