adomakin's Avatar
Help, before i buy my k27 high flow!
Beep Beep has just got me thinking about garret gt turbos.
im building a 3.3 turbo with 7.5-1 comp, sc cams , headers, 1bar spring and (up until five mins ago) a k27 high flow.
would a garret gt series turbo be a better bet? are they a better turbo? if so, why?
help!!!!!!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 04-07-2004, 11:01 AM
beepbeep's Avatar
Me like GT veeery muuucho.
They are good beacuse they:
1. Have fewer parts.
2. Are computer designed
3. Have easily available maps that help you to chose right size w/o having to speak with black magic shamans.
4. Their maps show good efficiency numbers.
5. You can get them any way you want: black, white, Ball Bearing, floating, built-in wastegate etc.
6. They are usually installed on our Scania and Volvo lorries which make them easy to find
Help yourself:
http://project911.luminasweden.com/garrettcatalog.pdf
Thank you for your time,
Old 04-07-2004, 12:12 PM
adomakin's Avatar
i seeeeee..................jesus. why can't there be just one turbo manufacturer?!
Andy
Old 04-07-2004, 12:15 PM
aseem's Avatar
I believe the Kokeln turbo is a garret unit. Anyone that have experience with the Kokeln?
http://www.kokeln.com/products/911turbo_7689/turbo.shtml
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 04-07-2004, 02:42 PM
David's Avatar
I'm don't really know all the facts about it, but I've heard the Garrett is designed for a watercooled engine and there are different oil cooling requirements so changes are needed for the oil supply.
Old 04-07-2004, 02:51 PM
