Most common rebuild mistakes
Reading all the posts here gave me an idea. With the horror stories and the fact that we all make mistakes, what do you think is either the most common or worst to make during a rebuild (on our 911s of course). Don't forget to name the size/year of the engine.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 05-05-2004, 01:08 PM
350HP930's Avatar
With any type of split case motor I would say case sealing.
I have seen enough posts here to indicate its also a big bugaboo with 911 motors.
Old 05-05-2004, 05:24 PM
Case sealing, guilty as charged.
Worst part is, you have to go all the way back to the beginning and start over. It's like rebuilding the engine twice. Great experience, but your off the road while you are doing it.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 05-05-2004, 08:15 PM
Alan Cottrill's Avatar
I forgot to put the seals on top of my oil pump.
didn't realize until I got the case all put together.
big AL
'77 911
Old 05-05-2004, 11:34 PM
Irrationally exuberant
ChrisBennet's Avatar
Yep, case sealing.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-06-2004, 04:00 AM
Probably not having Wayne's book or failing to use this board as a resource. Both of those would eliminate a LOT of headaches.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-06-2004, 07:49 AM
No Expert
jgparker's Avatar
Re-using Dilivar head studs is my biggest mistake. I’ve found some real doozies on engines I've pulled apart too. Like hand installed time-serts on head studs, and radically wrong spring height settings for the cam used.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-06-2004, 08:27 AM
Navin Johnson
TimT's Avatar
Or realizing you forgot to install the pilot bearing in the flywheel..
after you have the engine tranny back in the car
'69 911 GT-5
'75 914 GT-3
and others
Old 05-06-2004, 10:47 AM
Thinking you can do it for less than $3000. Jim
Old 05-06-2004, 12:05 PM
Author of "101 Projects"
Wayne 962's Avatar
- Oil pump seals forgotten
- Not cleaning the cam towers well enough
- Not installing the starter ring gear
- Installing the cam sprockets backwards
- Wrong distributor drive gear
- Reusing rod bolts
- Not keeping the chaing tight when working with the timing/chain tensioners
- Forgetting to install the sheet metal between the cylinders
- Mixing up the left and right camshafts
There are lots of mistakes to be made...
-Wayne
Old 05-06-2004, 12:12 PM
oneblueyedog's Avatar
Installing the metal air guides between the cylinders backwards.
78SC coupe, Silver Metallic
Old 05-07-2004, 06:38 AM
No Expert
jgparker's Avatar
I have to agree that Jim Sims answer is the probably the most common mistake. Everyone seems to think they can do a rebuild for $3000 until they get deep into it.
JP
Old 05-07-2004, 04:15 PM
How about not removing the cam housing spray bars for detailed cleaning..
I did remove mine due to paranoia, and found a good amount of junk in there.. I guess its more piece of mind really...
Old 05-10-2004, 08:41 PM
adomakin's Avatar
Rebuilding my 75 2.7s and only repairing the two pulled stud threads, then pulling two more on the other side of the engine less then a thousand miles down the road. NICE.
If id have just known about this place it would have never happened.
Andy - on his second rebuild (400hp 930) armed with the book and $hit loads of money.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 05-10-2004, 11:14 PM
Wayne 962's Avatar
JP
As I mention in the book, you can indeed sometimes get away with a $3K rebuild if the following is true:
- Aluminum case
- Reusable pistons & cylinders (Nikasil)
- No broken head studs or broken parts (bearings, etc just wore out)
- You do all the work yourself
-Wayne
Old 05-11-2004, 01:11 AM
Right now, my top-end will be in the neighborhood of 2k with the clutch work.
Old 05-11-2004, 04:38 AM
Unfortunately, many of the engines are run until something breaks and prompts the rebuild. Then it is more than just worn bearings; expensive new parts and machining are required. It would interesting to determine how many rebuilds were done for $3000 or less and how many were above $6000. Jim
Old 05-11-2004, 06:55 AM
Doug Steinel's Avatar
Mark,
did you get the rest of those dilavar studs out?
77 911, 3.0L
Old 05-11-2004, 11:27 AM
Not yet Doug. Still trying to find someone with an O/A torch they are willing to rent or loan. GRRRRR!
Old 05-11-2004, 12:39 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
cylinders upside down
pistons upside down
Loctite on rod bolts
RTV silicon to block oil passages
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-11-2004, 02:01 PM
