Most common rebuild mistakes
Reading all the posts here gave me an idea. With the horror stories and the fact that we all make mistakes, what do you think is either the most common or worst to make during a rebuild (on our 911s of course). Don't forget to name the size/year of the engine.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
With any type of split case motor I would say case sealing.
I have seen enough posts here to indicate its also a big bugaboo with 911 motors. |
Case sealing, guilty as charged.
Worst part is, you have to go all the way back to the beginning and start over. It's like rebuilding the engine twice. Great experience, but your off the road while you are doing it.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
I forgot to put the seals on top of my oil pump.
didn't realize until I got the case all put together.
big AL '77 911 |
Irrationally exuberant
Yep, case sealing.
![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Probably not having Wayne's book or failing to use this board as a resource. Both of those would eliminate a LOT of headaches.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
No Expert
Re-using Dilivar head studs is my biggest mistake. I’ve found some real doozies on engines I've pulled apart too. Like hand installed time-serts on head studs, and radically wrong spring height settings for the cam used.
JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Navin Johnson
Or realizing you forgot to install the pilot bearing in the flywheel..
after you have the engine tranny back in the car ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thinking you can do it for less than $3000. Jim
Author of "101 Projects"
- Oil pump seals forgotten
- Not cleaning the cam towers well enough - Not installing the starter ring gear - Installing the cam sprockets backwards - Wrong distributor drive gear - Reusing rod bolts - Not keeping the chaing tight when working with the timing/chain tensioners - Forgetting to install the sheet metal between the cylinders - Mixing up the left and right camshafts There are lots of mistakes to be made... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Installing the metal air guides between the cylinders backwards.
78SC coupe, Silver Metallic |
No Expert
I have to agree that Jim Sims answer is the probably the most common mistake. Everyone seems to think they can do a rebuild for $3000 until they get deep into it.
JP
How about not removing the cam housing spray bars for detailed cleaning..
I did remove mine due to paranoia, and found a good amount of junk in there.. I guess its more piece of mind really... |
Rebuilding my 75 2.7s and only repairing the two pulled stud threads, then pulling two more on the other side of the engine less then a thousand miles down the road. NICE.
If id have just known about this place it would have never happened. Andy - on his second rebuild (400hp 930) armed with the book and $hit loads of money.
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going ![]() |
- Aluminum case - Reusable pistons & cylinders (Nikasil) - No broken head studs or broken parts (bearings, etc just wore out) - You do all the work yourself -Wayne
Right now, my top-end will be in the neighborhood of 2k with the clutch work.
Unfortunately, many of the engines are run until something breaks and prompts the rebuild. Then it is more than just worn bearings; expensive new parts and machining are required. It would interesting to determine how many rebuilds were done for $3000 or less and how many were above $6000. Jim
Mark,
did you get the rest of those dilavar studs out?
77 911, 3.0L |
Not yet Doug. Still trying to find someone with an O/A torch they are willing to rent or loan. GRRRRR!
cylinders upside down
pistons upside down Loctite on rod bolts RTV silicon to block oil passages Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Thread Tools | |
Rate This Thread | |
