Break-in Oil
Allot of what I've read recommends using a straight 30 weight non-detergent oil for breaking in a new/rebuilt engine. Who even makes that anymore, were do you get it?? What have others used?
Robert Williams 70' 911T |
NAPA
TRY NAPA
Castrol makes a straight weight oil that we use both during break in and normal operation beyond break in. It comes in 30, 40, 50, etc weights. I have gotten it from NAPA
Kendall
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
canna change law physics
I'm using Coastal 10W40, cause it's cheap and it is not staying in the engine long...Comes in 4 qt containers. I bought a case of 6 gallons for the inital breakin. Once that is over, I'm switching to synthetic.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Coastal/Castrol whatever it takes
72 Carrera RS replica, Spec 911 racer |
You Say Castrol
I say Coastal....
![]() -Wayne
And what about castor oil?
Mike 1986 930 |
Actually, I decided to go green and used Olive Oil. Extra Vigin for my blond!
Can you use 20-50 (my regular weight oil) after a top end rebuild? If not, what is the reason?
80SC |
Irrationally exuberant
I use Coastal 10W-30. Edit: Coastal 10W-30 is non-detergent.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 05-31-2004 at 05:46 AM.. |
Slumlord
My engine rebuilder recomended a slightly thinner oil for break-in of the rings, therefore 10W30 for break-in, then 15W40 later.
The thicker oil will probably work fine, but you want the rings to seat as quickly as possible, therefore the thinner oil is preferred. I previously thought the straight 30 would be better, but at operating temps it is thicker than 10W30, so I have revised my opinion.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Air Medal or two
we are talking the 1st 20 min right??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Slumlord
My alusil 'expert' says for full ring break-in time, several hundred miles. I'm doing it now, oil pressure is not a problem.
No Expert
I do 1K miles on organic oil (any name brand). After that, synthetic 15W50. Synthetics are slick enough to prevent things from wearing in properly.
JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Slumlord
I agree. Unless it is factory recomended, do not try to break it in with synthetic. The rings might glaze rather than seat in the cylinders..
