forgot lifting ring
I presume it is ok to undo the one case bolt to install the lifting ring without jeopardizing the seal?
The case has been sealed and torqued for a couple of days but I forgot the ring.
78SC Porsche Targa, 71 911T 86 Mazda RX-7 ITS SCCA racer 05 Porsche Cayenne 05 F350 Powerstroke 90 Miata |
do you need to lift the engine with it?
Well I guess I don't have to but the ring is what I used to lift the fully dressed engine up to my engine stand and what I planned to use to get it back down to the floor.
From your question I am hearing that it is not a good idea. I was thinking that given that it was at the top I could get away with it? Jamie
Bird. It's the word...
I would have thought loosening just that one nut for a short time wouldn't hurt.... But then again I'd defer to JWW
John Forcier Current: 68L 2.0 Hotrod - build underway |
no problem with loosening the nut and putting the ring back on, i just didn't think anyone really used that ring, other than the factory.
Author of "101 Projects"
Right - no problem. It's not likely to leak from there anyways even if the seal is disturbed...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
OK now I have to ask, JW how do you lift the engine to put it on a stand?
I couldn't resist posting this after that last question! You don't see that every day in your average Porsche workshop!
David |
Now in 993 land ...
You put one chain on the engine stand yoke and two chains on the engine mount on the other side. That triangle will be a nice setup to lift the engine. Once it is on the ground or your dolly, you can take off the enigne stand yoke and you are all set.
George |
No Expert
buy a bigger jack and a two legged stand. I've posted that pic too many times already.
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
i use a cherry picker and a 2" nylon woven strap. loop it around the bellhousing yolk, and around the motor mount crossbar. for engine only lifting, that factory loop is way off-center.
Right - the engine hook is not designed to lift just the engine only - it's supposed to lift the engine and tranny together.
I personally just use my AC Hydraulic jack, which elevates the engine to engine-stand height quite easily! http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_ACHyd1_pg1.htm -Wayne
