Damomma's Avatar
forgot lifting ring
I presume it is ok to undo the one case bolt to install the lifting ring without jeopardizing the seal?
The case has been sealed and torqued for a couple of days but I forgot the ring.
78SC Porsche Targa, 71 911T
86 Mazda RX-7 ITS SCCA racer
05 Porsche Cayenne
05 F350 Powerstroke
90 Miata
Old 05-14-2004, 03:48 PM
do you need to lift the engine with it?
206 637 4071
Old 05-14-2004, 04:29 PM
Damomma's Avatar
Well I guess I don't have to but the ring is what I used to lift the fully dressed engine up to my engine stand and what I planned to use to get it back down to the floor.
From your question I am hearing that it is not a good idea. I was thinking that given that it was at the top I could get away with it?
Jamie
05 Porsche Cayenne
05 F350 Powerstroke
90 Miata
Old 05-14-2004, 04:43 PM
Bird. It's the word...
Fishcop's Avatar
I would have thought loosening just that one nut for a short time wouldn't hurt.... But then again I'd defer to JWW
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-14-2004, 05:46 PM
no problem with loosening the nut and putting the ring back on, i just didn't think anyone really used that ring, other than the factory.
206 637 4071
Old 05-14-2004, 06:04 PM
Damomma's Avatar
OK now I have to ask, JW how do you lift the engine to put it on a stand?
05 Porsche Cayenne
05 F350 Powerstroke
90 Miata
Old 05-14-2004, 09:25 PM
magic930's Avatar
I couldn't resist posting this after that last question! You don't see that every day in your average Porsche workshop!
Old 05-14-2004, 11:14 PM
Now in 993 land ...
aigel's Avatar
You put one chain on the engine stand yoke and two chains on the engine mount on the other side. That triangle will be a nice setup to lift the engine. Once it is on the ground or your dolly, you can take off the enigne stand yoke and you are all set.
George
81 SC (sold)
Old 05-15-2004, 02:07 AM
No Expert
jgparker's Avatar
buy a bigger jack and a two legged stand. I've posted that pic too many times already.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-15-2004, 06:39 AM
i use a cherry picker and a 2" nylon woven strap. loop it around the bellhousing yolk, and around the motor mount crossbar. for engine only lifting, that factory loop is way off-center.
206 637 4071
Old 05-15-2004, 10:43 AM
Author of "101 Projects"
Wayne 962's Avatar
Right - the engine hook is not designed to lift just the engine only - it's supposed to lift the engine and tranny together.
I personally just use my AC Hydraulic jack, which elevates the engine to engine-stand height quite easily!
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_ACHyd1_pg1.htm
-Wayne
Old 05-15-2004, 12:27 PM
