echrisconnor's Avatar
Can carbon on your piston tops...
Can carbon on your piston tops increase your compression ratio? Yes this may be a silly question, but think about it. Say you've got .5mm or more of carbon build up on your piston tops. Isn't this almost effectively increasing your piston dome size. .5mm could translate to almost a half point increase in CR.
Not that this is an effective way to increase your CR, but is it ever a factor?
'76 911 Carrera 3.0
Old 05-21-2004, 12:00 PM
Friend of Warren
Yes it can. Of course when you get that much carbon build up you will probably get a case of serious engine run on when that hot carbon ignites the gas/air mixture when you turn the car off. And the carbon will not build up evenly on the piston so you will get a more uneven burn pattern. So while compression may go up, that does not necessarily translate to more hp.
Kurt V
Old 05-21-2004, 12:06 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Also if you search the forum, there are many who have described a procedure for easily removing the internal carbon from your motor.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 05-24-2004, 11:23 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Water cooled pistons ?
Carbon can be removed from piston tops every easily. In the eighties BMW had this problem with 6 cylinder engines and they ( BMW factory ) recommended pouring a small amount of water into each cylinder while the engine was running. The steam produced caused the carbon to break loose. Their problem if i remember correctly, was pour idle and detonation caused by higher compression.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-25-2004, 06:44 AM
thor's Avatar
It increases the compression but creates somes thermal problems i.e at the valves (hot spots) then it s not recommended to have to much carbon in the combustion chamber.
Old 05-25-2004, 09:16 AM
