rw7810's Avatar
Break-in Oil
Allot of what I've read recommends using a straight 30 weight non-detergent oil for breaking in a new/rebuilt engine. Who even makes that anymore, were do you get it?? What have others used?
Robert Williams
70' 911T
Old 05-17-2004, 08:47 AM
Send a message via ICQ to fly944
NAPA
TRY NAPA
Old 05-17-2004, 02:05 PM
Castrol makes a straight weight oil that we use both during break in and normal operation beyond break in. It comes in 30, 40, 50, etc weights. I have gotten it from NAPA
Old 05-17-2004, 05:34 PM
David's Avatar
Kendall
Old 05-18-2004, 06:18 PM
canna change law physics
red-beard's Avatar
I'm using Coastal 10W40, cause it's cheap and it is not staying in the engine long...Comes in 4 qt containers. I bought a case of 6 gallons for the inital breakin. Once that is over, I'm switching to synthetic.
James
Red-beard for President, 2020
Old 05-21-2004, 09:28 PM
Author of "101 Projects"
Wayne 962's Avatar
That's exactly what I do - have had good luck with Castrol...
-Wayne
Old 05-21-2004, 10:13 PM
Coastal/Castrol whatever it takes
Old 05-21-2004, 10:18 PM
red-beard's Avatar
You Say Castrol
I say Coastal....
James
Old 05-21-2004, 10:21 PM
And what about castor oil?
Mike
1986 930
Old 05-25-2004, 10:14 PM
red-beard's Avatar
Actually, I decided to go green and used Olive Oil. Extra Vigin for my blond!
James
Old 05-25-2004, 10:17 PM
Can you use 20-50 (my regular weight oil) after a top end rebuild? If not, what is the reason?
80SC
Old 05-26-2004, 07:53 PM
Irrationally exuberant
ChrisBennet's Avatar
I use Coastal 10W-30. Edit: Coastal 10W-30 is non-detergent.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-27-2004, 05:39 AM
Slumlord
Porsche_monkey's Avatar
My engine rebuilder recomended a slightly thinner oil for break-in of the rings, therefore 10W30 for break-in, then 15W40 later.
The thicker oil will probably work fine, but you want the rings to seat as quickly as possible, therefore the thinner oil is preferred.
I previously thought the straight 30 would be better, but at operating temps it is thicker than 10W30, so I have revised my opinion.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-31-2004, 05:34 AM
Air Medal or two
afterburn 549's Avatar
we are talking the 1st 20 min right??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-31-2004, 09:19 AM
Slumlord
My alusil 'expert' says for full ring break-in time, several hundred miles. I'm doing it now, oil pressure is not a problem.
84 Cab - sold!
Old 05-31-2004, 10:13 AM
No Expert
jgparker's Avatar
I do 1K miles on organic oil (any name brand). After that, synthetic 15W50. Synthetics are slick enough to prevent things from wearing in properly.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-31-2004, 10:37 AM
Slumlord
I agree. Unless it is factory recomended, do not try to break it in with synthetic. The rings might glaze rather than seat in the cylinders..
84 Cab - sold!
Old 05-31-2004, 10:39 AM
