Danimal16's Avatar
2.5 liter on a later aluminum case
Can a 2.5 liter short stroke be built with a later 3.0 or 3.2 liter aluminum case?
From reading the thread this would be the 66 mm counter weighted crank with the early 2.0 rods.
Dan
Old 01-08-2009, 10:52 AM
3 restos WIP = psycho
kenikh's Avatar
This is only possible with the custom crank built by Supertec; the OEM 66mm crank will not work. The early crank will not fit the later case.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-08-2009, 10:58 AM
Danimal16's Avatar
Thanks. I am learning about all of this. Is there a quick engine built on the 7R case. The search for parts begins.
Dan
Old 01-08-2009, 11:18 AM
Define what you mean by "quick". You can building anything from a 2.0 to a 2.9 on a 7R case. You can do short stroke (66mm crank) or long stroke (70.4mm crank). Possibly the easiest to find parts for would be a 2.7 RS spec motor with carbs in stead of MFI.
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 01-08-2009, 11:32 AM
kenikh's Avatar
The quickest, easiest, cheapest motor you can build goes like this:
70.4mm crank (dime a dozen)
84mm pistons from a 2.2E
Solex cams
SC oil pump
All of these parts are dirt cheap used in good shape and makes a nice high compression, eminently fun motor. You could find the parts quick, assemble it quick and have fun quick for far less than most combos.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-08-2009, 12:05 PM
911 tweaks's Avatar
Kenik... can you elaborate a bit further on what else to do with your suggestion ??
I presume mfi for induction since you recommended using "E" heads ?? OR plug the holes & run carbs ?? (mfi ain't cheap so am I missing something here ??)
Lastly, what about timing (6 or 12 plug dizzy or something else ?? ) & exhaust to use ??
If one were to make this set up, what ballpark hp are we talking ??
...I think I am about to drop some coin here...
Thanks for your input here!!
Bob
I live for 911 tweaks...
Old 01-08-2009, 12:39 PM
911 tweaks's Avatar
woops... sorry I missed that you recommend 84mm pistons from the 2.2E... so what does this mean for heads ??
Thanks again!
Bob
Old 01-08-2009, 12:42 PM
kenikh's Avatar
Bob
Plug the holes and use carbs. Single plug dizzy is perfectly OK for this config, as CR is still only around 9.5:1. My guess is HP would be around 175 with a fat torque band. Use any 2.2 or 2.4 small port head (T or E is fine with this config).
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-08-2009, 12:44 PM
Banned
Dan, This might help.
1975 2.7S with Carbs HP?
Old 01-11-2009, 08:46 PM
