Question Cam timing changed ???
Hi,
So I rebuilt the top end of the engine & everyone seemed fine so far
After my 1st track event (& ~500 miles total driving), I drained my oil, re-checked valve clearance, etc. just to make sure everything is ok after the break in period.
While I'm at it, I re-checked my cam timing using the dial indicator. Because of location, I ended up checking cylinder #3 and #4.
And that's the surprise - the value changed... I re-checked my cam timing, must be at least 5 times before I put the engine back into the car. They were 1.575.
Now, #3 is at 1.31 and #4 is at 1.46 I supposed this can be due to chain slacks (when I checked/set timing, I used vise grip/tensioner per Wayne's book)? Just want to tap into the knowledgeable group here to see if this is normal & if my guess is right.
Thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 05-27-2004, 08:35 PM
That's what you get for checking them again.
Old 05-27-2004, 08:55 PM
Irrationally exuberant
ChrisBennet's Avatar
I don't think the chain tensioners apply enough pressure to make an accurate measurement. Using a different valve than the one you originally timed it with (#3 vs #1) probably introduces a little more error as well.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Jeff Alton's Avatar
The tensioners do not apply enough pressure to the ilder arms. I just did this today. Timed cams in the morning and then tonite I figure I will check them one more time with only the tensioners in instead of a mechanical means to tighten the chains. Nearly crapped my shorts when my perfectly timed cams seemed to be out. Pulled a tensioner and went back to mechanical tensioning to check, and the timing is spot on!
Cheers, Jeff
www.turn3autosport.com
Old 05-27-2004, 11:26 PM
Author of "101 Projects"
Wayne 962's Avatar
That's a good explanation. Also, the engine will settle after it's run in - I don't think it's unusual to see some variations in the cam timing. When you re-adjust the valves after a few hundred miles, they are typically out of adjustment too...
-Wayne
Old 05-28-2004, 12:06 AM
Thanks for the confirmation guys... kinda what I was thinking as well.
The good news is that all my intake valves don't need adjustments It would have been a royal PITA to adjust cylinder #1 (which is why I checked the cam timing off #3 instead). Will continue my mission with the exhaust valves tonight.
Old 05-28-2004, 08:43 AM
there is also some varation from the crank gear not comming around to the same chain link at every rotation when rechecking timing. it takes 9 revolutions to bring everything back to original start of gear and chain link.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-01-2004, 10:07 PM
Wow, you actually know it takes 9 revolutions Amazing!!!!
I did check the timing twice and they do change ever slightly each time (by ~.01mm). I thought that's operator's error but maybe its just the chain then...
At this point, I'm kinda taking the noted & understood attitude. After many moons, I want to drive the car unless its really really bad
Old 06-02-2004, 06:48 AM
350HP930's Avatar
It helps to thouroughly oil your chain before starting the process since the chain length will noticibly change depending on if its a little dry or loaded with oil.
Old 06-05-2004, 03:18 PM
Now in 993 land ...
aigel's Avatar
I think this is a good example why any spec comes with a tolerance. What's the tolerance on this? I would not worry about it unless it is far outside the tolerance....
George
81 SC (sold)
Old 06-07-2004, 08:11 PM
