WydRyd's Avatar
Question Boring Alusils from 95mm to 98mm?
Hi,
I have a used set of good Alusil Cylinders and I was just wondering if anyone here has ever bored out Alusil cylinders?
Once bored, can they be re-plated in Nikasil or Electrosil?
Just contemplating the idea for a future upgrade path, using JE 7.5:1 Pistons.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-13-2004, 08:03 PM
KobaltBlau's Avatar
Yes you can bore them to 98mm and replate them in nikasil. If they are from a Carrera 3.2 no problem. with 3.0 cylinders you have to worry about the sealing ring groove. EBS racing does this here in the US. US Chrome can also do the plating but I'm not sure if they do the machine work.
Andy
Old 09-13-2004, 09:51 PM
geof33's Avatar
3.2's... yes... 3.0's... no... Eric is correct...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 09-13-2004, 10:48 PM
WydRyd's Avatar
Cool, thanks guys!
I guess I will hold onto my used set then, for a rainy day
Merv
'89 911 Turbo Cab
Old 09-14-2004, 10:20 PM
jimz61's Avatar
I'm also under the impression that 3.3 is a no. Can't go 97 to 98mm.
Old 09-20-2004, 12:25 PM
Alan.UK's Avatar
What about the 95mm cyclinders from an early turbo, can they be used ?
Alan.UK
Always learning
Old 09-21-2004, 10:54 AM
Irrationally exuberant
ChrisBennet's Avatar
Alan.UK
Not if they have the sealing rings. I can't remember if those do.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-21-2004, 06:44 PM
canna change law physics
red-beard's Avatar
See the thread on Alusil. They do not need to be coated. The Silicon goes all the way through the part. It will need to be honed using the special paste.
James
Red-beard for President, 2020
Old 09-22-2004, 06:13 AM
WydRyd's Avatar
Just thought I'd revive this thread.
So, if I bore out my original 95mm 3.2 Carrera KS Alusils, I don't need to re-coat them in Nikasil?
Who offers the best boring / honing service and how much does it typically cost for a set of 6?
Also, my Alusils are magnetic inside. I though Alusils aren't megnetic and only Nikasils are?!?
Can someone confirm please?
Merv
'89 911 Turbo Cab
Old 02-12-2007, 08:52 PM
Send a message via Yahoo to Lukesportsman
Merv,
Certainly the KS may have consistant alloy all the way through. BUT, If you don't wish to buy KS pistons in the larger diameter.....and you don't for the boost your running then YES coat for JE's.
I believe your thought pattern on magetism is correct.....hmmmm. Dumb question, how did you determine they were Alusils to begin with? Are they shiny on the outside, kind of like cheap Al paint appearance or do they look similar to your Mahl from the outside?
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-13-2007, 07:51 PM
89turbocabmike's Avatar
merv, I've got two sets of 3.2 cylinders here, one alusil and the other nikasil. Only the nikasil are slightly magnetic. The nikasil have a traditional cylinder look/color with cross-hatching, the alusil have a uniform frosted silver look without any honeing marks. I'll get some pics posted up soon.
Old 02-13-2007, 08:59 PM
WydRyd's Avatar
Well, they are definitely KS cylinders, which I was led to believe were ALL Alusils. The outside is not shiney... they look like MAHLEs. Here's some pics:
Merv
'89 911 Turbo Cab
Old 02-24-2007, 05:27 PM
I would say those are alusil based only on the first picture. Do you see how the light reflects off the fins in the first picture? The alusil cylinders look almost glassy on the outside when they are cleaned. Put them in the dishwasher (when wife is not home) and you'll see them look shiny on the outside. They can be plated to nikasil if you desire.
-Andy
Old 02-25-2007, 08:32 AM
Yup, I'd agree those are alusil, they have that uniform frosted silver look. Also take a small magnet(the stronger the better) and place it in the bore. The nikasil's will have an obvious attraction dependant on the strength of the magnet, the alusil's none.
Old 02-25-2007, 10:48 AM
It doesn't really matter what they were originally as long as they ARE 3.2's which they are since they're from your 3.2. You might as well bore out KS cylinders since they have virtually no resale value. Though when I last checked in USA, they were getting about $1200 for a bore and plate. This puts them pretty close to other options out there.
A curious note: Would KS metallurgy be any better with JE's than the known problems of Mahles? Maybe Charles N. will chime in on the this aspect when the work week begins.
Luke S.
Old 02-25-2007, 12:37 PM
WydRyd's Avatar
I've done this test and there is a DEFINITE attraction to the bore. The magnet sticks to the bore! I'm not sure what this means, but I assume it has probably been plated with Nikasil sometime in it's life, since everyone tells me that Alusils do not attract magnets!
Steve Weiner quoted me in the $800 region to have them bored to 98mm and replated in Nikasil, which I think is a pretty darn good price (& I trust Steve would do them properly). Add a set of turbo spec JE's for $800 and you're good to go. I wouldn't run extreme boost with such a configuration, but for 1.0bar @ 7.5:1 C/R, they'd live fine.
Hmmm, food for thought
Merv
'89 911 Turbo Cab
Old 02-25-2007, 11:22 PM
