up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
2.0 Heads On A 2.2?
Will 2.0 heads fit ? If so, what needs to be done to make them fit ? I know these aren't the best heads to use...Thanks
Scott Kinder
kindersport @ gmail.com
Old 06-24-2004, 12:21 PM
neilca's Avatar
I actually wanted to go the other way using 2.2 heads on a 2.0. I was told by Wayne that it had been done before, but it required an adapter of some sort. I decided to look into sleeving 2.2 cyulinders to the 80mm bore in order to keep my engine legal for the class. I believe you could machine the heads to the 2.2 configuration but it would be pricey.
Good luck,
neil
Old 06-25-2004, 05:24 AM
Try not, Do or Do not
Henry Schmidt's Avatar
2.0 to 2.2 and back again
It is a simple modification to convert 2.0 heads to fit 2.2. The cost is $225 and takes one day turn around.
The adapter to put 2.2 heads on a 2.0 cylinder was invented by SUPERTEC and they are available for $250. These adapters are available and race proven.
Because this modification is not legal for some vintage racing groups, I won't tell you who, but believe me, if you're racing vintage on the west cost, you are running against this conversion.
Resleving cylinders leave you with very thick cylinders ( poor cooling) and a $600 bill.
Below are two ( 2.0) heads converted for 2.2. Note one is twin plugged.
Also below are the conversion shims to put 2.2 heads on 2.0 cylinders.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-25-2004, 07:12 AM
