Tim L's Avatar
rod balancing
While my engine is apart I was going to balance my rods. My question is where do you grind metal off the rod to balance both ends and the total weight?
Thanks,
Tim
Old 06-24-2004, 12:29 PM
Irrationally exuberant
ChrisBennet's Avatar
Have you weighed them yet? Sometimes they are very close right from the factory.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-24-2004, 12:43 PM
Tim L's Avatar
Yes, I did weigh them they are: 644.8, 643.7, 643.6 643.4 645.1 and 644.2 with the big end weight 460.3, 459.8, 458.5, 457.6, 459.7, and 457.7. I was thinking I could get them closer.
Thanks,
Tim
Old 06-24-2004, 12:52 PM
Weight can be taken off both ends, big end and small end. However, since the big ends are rotational and the small ends are reciprocating weights, all big end and all small end weights should be as close as possible. You can purchase a jig to consistently measure the ends on an accurate gram scale.
Sherwood
PS
To remove weight, there is usually extra material at the top of the small end and at the bottom of the rod cap. You can also smooth the surface of the casting/forging. Good idea also to have the rods shot peened for added durability.
Old 06-24-2004, 02:46 PM
