turbo dave's Avatar
2.7 heads on 2.4 cylinders?
Will they fit (is the OD of a 2.7 cylinder the same as the OD of a 2.4?) Obviously the ID is different, but I understand that the Alusil/Nicosil cylinders are thinner wall. Can I use my 2.7 heads on cast iron 2.4 cylinders (cast iron)?
Thanks,
David Schultz
1973 911T 2.7
Old 07-06-2004, 08:20 PM
the bevel around the hemi combustion chamber on a 2.7 head would keep the head from contacting and sealing to the 2.4 cylinder surface, inboard of the head gasket o ring. a 2.4 head on a 2.7 works fine though, and raises the compression slightly because it's not beveled for the larger cylinder. same basic head, but one's beveled.
206 637 4071
Old 07-07-2004, 08:00 AM
turbo dave's Avatar
Thanks, John, thought it was a long shot.
David Schultz
1973 911T 2.7
Old 07-07-2004, 10:00 PM
911SCfanatic's Avatar
On the flip side, I want to use my 73.5T 2.4 heads on a 2.7 cylinders. What additional machining, if anything, needs to be done to make this work? Looks like porting the heads to S-spec will cost ~$650 through EBS--cheaper than getting S-heads. Also, about how much additional compression do I get? I was planning on going with the 9.5:1 JEs already.
Bill G.
'68 911 Ossi Blue coupe
Old 09-02-2004, 10:50 AM
2.4 heads on a 2.7 are a bolt-on. and they raise the compression a tad. (as long as you don't have a wierd piston crown that would contact the unbeveled edge of the combustion chamber). they work fine with CIS pistons and euro 2.7 (MFI) pistons.
206 637 4071
Old 09-02-2004, 06:01 PM
JW, any experience with high compression JE's? Should I have the combustion chamber beveled, if that's possible, as a precaution? And I suppose if I have the decks machined then I'll have to be even more cautious.
Bill G.
Old 09-03-2004, 06:08 AM
might as well use 2.7 heads if you need to bevel them. same head other than the bevel. hard to say if the J&Es will clear. if there's a flat area around the crown, maybe, but if the curve of the crown goes all the way to the edge, then probably not. a test assembly with clay should tell you.
206 637 4071
Old 09-03-2004, 08:03 AM
