Unregistered
sammyg2's Avatar
Show me your engine stands please
I broke down and bought one of them fancy 911 engine stands with the bracket and mount, but I don't know what I'm going to attach the mount to (the thing that looks like a bearing).
I don't have a work bench heavy enough to bolt it to, I'm thinking of modifying a standard engine stand abd bolt it to that.
Any suggestions or pics will be greatly appreciated. Tanks.
Old 08-07-2004, 12:56 PM
No Expert
jgparker's Avatar
I would just use the base from a universal engine stand unmolested. Most will fit the yolk without issue. I like the kind with two legs so I can jack the engine up to the stand. I'm not sure the advantage of using the vice.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 08-07-2004, 03:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Ditto on what JG said but if you have the vice already, I'd get a plate welded to the top of a normal engine stand (after cutting off the top) and then bolt the "vice" to the plate.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-07-2004, 04:37 PM
magic930's Avatar
I've got one just like JP's. Got it on ebay for about $40. The Porsche Yolk slipped right in. The vice is not needed.
Old 08-07-2004, 05:19 PM
Licensed User
Shuie's Avatar
Got the $40 750lb version from Harbor Freight. The yoke works fine on it
Old 08-07-2004, 05:54 PM
fancytown
For a one person engine drop and mounting on the stand, do like JP said, buy one with the two legs instead of a "T" leg. This way, your floor jack slides right in between, and you can lift your engine, with yoke attached, onto the stand.
all cars sold.
Old 08-07-2004, 06:16 PM
Here is mine.
Brian Keith Smith
Old 08-08-2004, 07:57 AM
mike95125's Avatar
http://www.zdmak.com/wbstore/main.asp?action=CAT&CAT=PORSCHE%20TOOLS
I use this one, P201WR for $149 (halfway down the page). It's just the ring for the stand, not the whole cage. It's awsome because it uses a regular engine stand/mount.
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 08-08-2004, 09:19 PM
Unregistered
sammyg2's Avatar
Thanks. I didn't realize the yoke would fit in the hole of a standard stand, that makes life much easier.
Old 08-09-2004, 07:22 AM
