Unregistered
Show me your engine stands please
I broke down and bought one of them fancy 911 engine stands with the bracket and mount, but I don't know what I'm going to attach the mount to (the thing that looks like a bearing).
I don't have a work bench heavy enough to bolt it to, I'm thinking of modifying a standard engine stand abd bolt it to that. Any suggestions or pics will be greatly appreciated. Tanks. |
No Expert
I would just use the base from a universal engine stand unmolested. Most will fit the yolk without issue. I like the kind with two legs so I can jack the engine up to the stand. I'm not sure the advantage of using the vice.
Good luck, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Irrationally exuberant
Ditto on what JG said but if you have the vice already, I'd get a plate welded to the top of a normal engine stand (after cutting off the top) and then bolt the "vice" to the plate.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I've got one just like JP's. Got it on ebay for about $40. The Porsche Yolk slipped right in. The vice is not needed.
David |
Licensed User
Got the $40 750lb version from Harbor Freight. The yoke works fine on it
fancytown
For a one person engine drop and mounting on the stand, do like JP said, buy one with the two legs instead of a "T" leg. This way, your floor jack slides right in between, and you can lift your engine, with yoke attached, onto the stand.
all cars sold. |
Here is mine.
Brian Keith Smith |
http://www.zdmak.com/wbstore/main.asp?action=CAT&CAT=PORSCHE%20TOOLS
I use this one, P201WR for $149 (halfway down the page). It's just the ring for the stand, not the whole cage. It's awsome because it uses a regular engine stand/mount.
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me. -74 914 with 74 2.7 CIS -74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system. -74 BMW R90 |
Unregistered
Thanks. I didn't realize the yoke would fit in the hole of a standard stand, that makes life much easier.
