RPM's drop slowly between shifts
Hey Guys..quick question. What would cause my fresh rebuilt 3.2 short stroke to keep the rpm high between shifts ( actually they slowly drop down when you come off throttle ). Car idles nicely, just kinda hangs the revs between shifts.
Old 08-03-2004, 07:32 AM
jluetjen's Avatar
What sort of induction system are you running? CIS, Carbs or something else?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-03-2004, 09:58 AM
echrisconnor's Avatar
If the car runs CIS, it's almost certainly your Deceleration valve. The vacuum line to it can be plugged and revs will drop very quickly. Or depending on the year of the system, they're adjustable.
If it's carbs, or motronic, I can't help ya'.
chris
'76 911 Carrera 3.0
Old 08-03-2004, 10:49 AM
oops, yep its CIS.
Old 08-03-2004, 12:03 PM
Grady Clay's Avatar
It can also be a vacuum leak. Damaged air box?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-03-2004, 12:47 PM
happened to me on stock CIS
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2004, 06:40 PM
Thanks guys I tweeked the decel valve and that seems to have cured that issue..its does a strange thing after it warms up...hangs at 2K once it reaches 180 deg. Starts normal from cold, ck'ed the AAR open when cold /closed when hot. Idles great from cold start to 180 then it hangs..any thoughts.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 08-09-2004, 02:00 PM
Originally posted by Mysterytrain
..any thoughts.
try disconnecting it. On my system's decel model it was removing the small top control hose and pluging the hose.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2004, 02:15 PM
Have you checked your warm and cold control pressures? Could be a fuel pressure issue.
Alternately, have you blasted around with carb cleaner and looked for vacuum leaks?
'76 911 Carrera 3.0
Old 08-09-2004, 03:50 PM
too much carpet and mat around the gas pedal. =)
206 637 4071
Old 08-09-2004, 03:56 PM
don't you all laugh.. it happened to me wearing clunky boots that pushed the mat foreward.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2004, 04:13 PM
Hey, that's why I wasn't getting WOT for a while. Fixed it and it was like free horsepower!
'76 911 Carrera 3.0
Old 08-09-2004, 04:14 PM
Update..I removed the vac line from the top of the decel valve. Plugged the line and plugged top of the valve. Went out and drove the car and got it good and hot. The rev's go down faster then Monica Lewinsky. Feels like carbs. The fast idle problem is gone. Problem is that coming off the throttle from high revs the car will die. I'm thinking defective decel valve.
Peace, Ron
www.ronorlando.net
Old 08-10-2004, 06:17 AM
they are adjustable ya know.
206 637 4071
Old 08-10-2004, 08:18 AM
John, I've cranked the little bugger all the way down to the point were the rev's drop off fast (as if its plugged) but the idle crawls back up to 2K when the engine is hot. I think it leaks. I think there is another test I can perform ( from the shop manual) pinch off the rear hose that comes from the side of the unit, a change in idle indicates leaky valve.
Old 08-10-2004, 08:51 AM
In my CIS days I ran 1k rpm idle and a richer mix than spec O2.
"defective decel valve".. probably.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-10-2004, 10:35 AM
Figured I should update this thread..replaced the decel valve and that problem is solved.
Peace, Ron
www.ronorlando.net
Old 08-26-2004, 11:40 AM
thanks
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-26-2004, 01:40 PM
