Plavan's Avatar
To make a long story short. From what I understand, they were doing alot of R&D and were using some type of Buick rod that Carrillo made and put it in the 911 race motors. I do not know the specifics, but alot of the motors were throwing rods. At the time we just knew that Carrillo rods were busting sunroofs in the cases. There is still alot unknowns with what was really happening. Maybe just one of those "Racer Secrets".
Regardless, with my Dad's experience with Carrillo's (broke a rod) and from what I have seen (Carrillo's fault or not) I would not buy a set. I would opt for something else. Just my .02 cents
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 10-23-2004, 01:59 PM
jluetjen's Avatar
We are using 2.0L rods (reconditioned of course)
Plaven; are you sure that you don't want to use 2.2 rods instead? The 2.0 rods are definitely not as beefy as the 2.2's. I've got a set of the 2.0's here and if you put one of them side by side with a 2.2 rod, you'll see how much more material the 2.2's have around the big end. Since you were talking about rod failures, I figured that I'd just bring this up.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-23-2004, 03:27 PM
Plavan's Avatar
No worries with the 2.0L rods. They will be fine. The guys at Aase said they will work great with ARP rod bolts. I do not know if ARP makes rod bolts for the 2.2 rods now (they did not in the past) I even had a set of 2.2L rods and they said go with the 2.0L. They are a little lighter than the 2.2L and some people have had more problems with the 2.2L's than the 2.0L's. You refurb these race motors so often, you will see a problem before it develops (hopefully, knock on wood )
Plus, I do not go over 7500 RPM. My shift light is set at 7300.
Chad Plavan
Old 10-23-2004, 04:12 PM
Plavan's Avatar
Here is the first picture of this beast. More to follow.
Chad Plavan
Old 10-24-2004, 01:45 PM
