Motor Meister
Anyone use them. I am looking for a rebuild on my 87 911. Usual 100k starting to smoke quite abit. At start up and after idle. Any tips? Other places?
Thanks in advance. |
I would rather be driving
Use the seach button in the upper right corner and search for MM. There are some interesting opinions.
Lots a great builders in the CA area.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Unregistered
Do a search, plenty of posts about motor meister, almost all of them negative.
I have never used them myself because of all the alleged horrible things I've heard about their work and ethics. |
go see TRE in north hollywood. sounds like the valve guides are worn out, which is typical of 100K carreras. a simple valve grind is probably all you need.
