Ring end gap
Hello,
I am concerned that my ring gap is off for the second compression rings. All of my cylinders are size 0 and the upper ring and oil ring are with in tolerance according to my Haynes 911 book, but the second ring should be .15-.35mm and it is actually around .56mm (I stopped measuring after the tolerance was exceeded by so far). Is this normal? My rings are Goetze stock for a 2.7L 90mm. Thanks, Mike
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me. -74 914 with 74 2.7 CIS -74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system. -74 BMW R90 |
I think that I found the answer that I was looking for. It was in Appendix A. It said that 1.00 mm is the limit. I thought it was wierd that there is a stated tolerance in all of the pubs, but there is a final tolerance that is different from the stated range. Still learning...
the ring to land clearance should also be speced.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ronin,
those specs were perfect, luckily. Thanks, Mike
