Engine Complete!
Here's a few pics of my completed engine. The engine came out last November and its been a long haul to get it done, I never thought it would take so long. When I took it out, the engine was a stock 3.3L except for a Kokeln IC and an MSD iginiton. I got it in the car today but won't be firing up till later this week.
This first pic is what the engine was like when I pulled it out: And what it is now: engine specs: 3.4L 7.5/1, ARP rod bolts and head studs K27 EFI (DTA) Kokeln IC Fabspeed Muffler
David |
Very nicely done. congats
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Looks great
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Nice Job! looks fast!
Andy |
Very nice, I hope my project looks as good. Could you post some pics of the back side? Is that a Fabspeed muffler? Is the aluminum AC compressor bracket stock on an '87?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I'll have to look through my pictures and see if I have any from the back. The engine is now in the car so it would be hard to get new ones! What do you want to see in particular?
It is a Fabspeed muffler with a modification to hold an O2 sensor after the turbo. The AC bracket is stock.
David |
Looks great! Tell us about the EFI?
Beautiful! And as thethrill said, can you please elaborate on the mods - its definitely not stock injections & what turbo do you have in there? And what headers are you running - they dont look stock B&B as I thought the wastegate pipe is smaller?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
The EFI is documented on the 911techforum here is the link:
CIS to EFI for the 930 I intend to update that thread when I find some time. In a nutshell the EFI uses some aluminum CIS blocks (powerhouse) modified to accept efi injectors and a rail made from stock fuel rail. The ECU is a DTA P8, others on this group have had good success with it. Although I haven't turned my key yet! The turbo is a K27-7200 with the stock headers for now. Other mods are SC cams and 3.4L P&C's and a Patrick Lightweight Flywheel. Here is a shot of the rear as requested. I think I took this when trying to figure out how to mount the coils (I used a Bosch VW coil pack).
David |
Looks great David!
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
Cool, I was curious how you mounted your ignition and fuel pressure regulator.
What brand of regulator did you use and what type/brand of ignition is that? Where did you put you're BOV? Is the hose with plastic barb above the date the brake vacuum hose? Mine was disconnected by the PO (I wondered why the brakes were so heavy!) and I'm not sure which line it is. What type of paint did you use on the engine cowling and valve covers? Thanks
The regulator is an Aeromotive A1000-6 (2 6AN inputs one 6AN output) Coils are a Bosch 3pack wastespark coil as used in a VW V6. Crank trigger is similar to the ones sold by clewett. The DTA-ECU controls the spark duration etc.. The BOV is now vented to atmosphere thru a small KN filter. The tube you mentioned is the brake booster.
David |
faster than I once was...
Very nice job - are you for hire? ha
~Dave |
Irrationally exuberant
Way to go! Congrats on your project.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks for the kudos, but if you read my other post "Engine Runs" you will see I am pulling the engine again to track down some oil leaks
David |
![]() -Chris
Yeah, but look how much more you will have learned when you're done! I still think you've done a fantastic job! Looks great!
~Dave |
Warren Hall Student
Originally posted by magic930
Thanks for the kudos, but if you read my other post "Engine Runs" you will see I am pulling the engine again to track down some oil leaks. I think everyone probably goes through this. I just put a 2.4T together and got a leak. It was coming from the left side between the chain housing and the cam housing. So I opened up the left chain housing and removed the chain sprocket on the left cam. Just as I suspected I had not torqued the three bolts that tighten down the round flange for the O-ring gasket between the two parts. Lucky for me an easy fix and now no leaks!!! Good luck.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Hey, I don't understand that thing the plug wires are attached to. Some kind of distribtor coip pack?
Its a VW VR6 coil pack (Volkswagen). The metal part underneath the brown coils is basically an empty box VW used to hold the coils. The engine does not have a distributor any more, it has a crank sensor for timing.
David |
