Irrationally exuberant
3.6 conversion pump drive solution
Most 3.6 motors come with a power steering pump driven by the one of the cams. When you use a 3.6 in an earlier car you ditch the pump and install a cap ("camshaft block off cover") to cover the exposed cam drive. Patrick sells one of these caps for $89 and I think Porsche or PMS sells one. This was my lighter, cheaper Yankee solution:
I chopped the pump drive off the end of the cam and installed a cam housing plug for less than $3 (my cost). -Chris EDIT: The plug is Porsche part # 930 105 161 00
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 09-22-2004 at 07:03 AM.. |
Chris,
Are those caps simply pressed in or do you use some sort of sealant as well? |
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Will this plug affect the cam's placement, i.e. place it out too far and screw up the chain alignment?
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
-Chris EDIT: I'm not sure if the 964's have a blockoff cover or a different cam. I could be wrong on this.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 02-27-2005 at 10:29 AM.. |
Bandwidth AbUser
$3 vs. $89 or more? Way to go Chris!
Jim R. |
A very good solution indeed!!! Thanks for sharing.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
A good use for the power steering pump is to circulate the gearbox oil..cooler and or squirters..
Kind regards David |
-Chris
so you have to remove cam to chop off the drive end or did I miss something. Great info, thanks! getting ready for 993 install in my 914/6.
Jim |
I am having John (camgrider) cut the drive off when he regrinds my cams. Thanks for the tip Chris!
Jeff
-Chris
Senior Member
This seems nice, but is it a proven solution? How do you know it's not going to pop off when things get hot and start flexing?
The end plug for cylinders 1,2,3 never seems to pop off, so I would think having the same solution on both sides would work. This is the way all the pre 964 engines are.
Jeff
Senior Member
OK. Forgot there was one on the other side already. Nice.
