GBStu's Avatar
3.0SC rebuild dilemma
I’m about to rebuild my 79SC engine, my question is: “is it worth going with the 98mm P&C’s if I plan to keep the CIS?” Whether I go with re-ringed 95mm or 98mm my plan was to change the cam and update to SSI’s.
I do have a few other questions:
1) What would be the best cam profile to use with the CIS? (I don’t necessarily need low end torque)
2) Are there any upgrades to the CIS system I can perform?
3) Is it worth going with 95mm “high compression” pistons?
Thanks for your help
Cheers
Stu
PS: I don’t mind spending the money, but it has to be worthwhile!
Old 10-26-2004, 06:42 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Yes plenty of info out there on the 3.0 cis and engine ideas. Just to let you know my dad's car has a 78 3.0, 20/21 cams, pop off valve, msd, SSI's with a two in two out muffler and is nice and strong. You can get the revs up there and it really pulls. A decent amount of low end grunt but nothing neck snapping. Right now we are debating whether or not to build it to a 3.4 or plop in a mostly stock 3.2
74 911s neverending story. two feet and a jetta for now.
Old 10-27-2004, 10:19 PM
