Sent my heads off the Henry at Supertec to get the heads in usable shape. I knew it was leaking around one of the intake valves and 5 of the exhaust valves. Oh yeah, and they were pretty nasty looking...
Here are the before pictures: Please note that my instructions to Henry were not to help me build a show motor or a race motor. My instructions were based on my latest project, a 1972 911T targa. It needs a motor and I have a supposedly good 2.7 that I am doing a re-ring topend on to replace the 2.4 that only runs (but still runs) on 4.5 cylinders. I am on an extremely limited budget and my goal is to build the motor to last 30k-50k (probably 6-10 years as my second 911) miles so I can drive it instead of just letting it sit in my garage like it has the last 7 years. Budget, budget, budget. My instructions were something like "Do the minimum so I can drive it a while." No porting, no polishing, no twin plug, no new parts unless the old ones are out of spec and unlikely to last for the target mileage...My next rebuild will hopefully happen BEFORE I need a new motor and I plan to take my time and do everything perfect. This time it's about getting something instead of nothing. Anyway, Henry fixed me up. It was a good news/bad news thing. Good: - Heads had had a recent valve work guides installed and so new ones weren't needed. Bad: - All exhaust valves were bent and needed replacing. Although the valve guides were OK the previous valve job was crap. - The heads were actually 2.4 and needed a chamfer machined in to clear the larger diameter pistons. - Needed some exhaust studs replaced and inserts Thanks to Henry for helping me get my parts in usable form. They came back looking better than I expected based on my instructions to him. He was a pleasure to deal with and I really like the product. It's always nice to get a little more than you expect rather than less. I can't wait to get my car in good running shape. Here's a few quick after pictures of one of the heads. I think they look better in person than the pictures. Happy motoring, Rob Oh, here's one of the car it's going to go ing while I'm here.
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
Banned
The pictures prove, what? He has a good bead blaster?
I like to hear of leak down numbers like 5% or less after the fix. Thats the proof that the job was really done. I am not trying to poo poo a good looking repair job, but just looks don't do the job. HOw about some numbers, before and after. Like for example valve stem clearence before and after. a picture of the valve seat before and after, pictures of the valve grind on the valve and seat, after. Some data on the spring pressure after. |
Nice POSTER!!! glad to see henry hooked you up and did his usual great job.
74 911s neverending story. two feet and a jetta for now. |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Bandwidth AbUser
The heads look good and that longhood targa is a beauty. I'm looking forward to reading that you've got it back on the road.
Jim R. |
What's the blue stuff?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
I would rather be driving
Those heads look fantastic. I have not doubt that Henry did them right!
The blue stuff looks like Dykem Blue. Its a machinist dye used for layout and also an indicator of removed material. I suspect it was used during the valve grind and lapping process.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
chill snowman chill!
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
he's baaaack!
like a superhero from "the incredibles" but with the hump.-LOOK! UP THERE-IN THE SKY-ITS.......ITS...'SNOWMAN!'
whoops. sorry jack!
Yeah Jack, I bet he's just passing off good looks to cover a $hitty job...you know Hnery, can't seem to do a darned thing right around here....
Rob, Good looking heads...I'd bet my life that those heads will WORK great too... R/ Dustin |
Banned
sorry, clump of snow fell on my head
but its good to be back. Heads do look good but do they really work? just kidding, really honest engine. I was just ranting and raving about some local work done by non green card carying labor. Very clean on the surface, but NOTHING done below the surface, a total fraud on the customer. What you see is not what you get. THese guys make all mechanics look bad. Nothing to do with the supplier here. Last edited by snowman; 12-07-2004 at 10:37 PM.. |
Try not, Do or Do not
Yes, just clean work is not enough. The specs have to fit the job. Are these heads perfect? No, but they are pretty nice. Someone before me had butchered the seats so we ended up cutting them a little deeper than we would like but they are all the same and all seal well. The valves had .0005 to .001 taper on the stems, well within spec. the guides are new. The spring were set at 35.0mm in and 35.5mm exhaust which yields a 85 lb seat pressure. We had to use a special cutter to clean up the heads because the seats were set so deep in the heads. This also caused us to use more shims under the spring seat than normal. These heads started their life as 2.4 heads and because they were going on a 2.7 we chamfered the chamber for clearance. Would new heads be better? Sure , but lets not throw out the baby with the bath water. These heads will offer years of service at a reasonable cost and no undue risk. Isn't that what we all want?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 12-17-2004 at 09:20 AM.. |
Unregistered
Aw come on Henry, a few hundred hours with a dremel and some polishing rouge would have made a huge difference, I'm disapointed!
Just kidding, IIRC I'm the one that posted a while ago that show don't make it go. Sounds like you found the right solution considering what the customer wanted and what the customer needed. Not an easy thing to do but you made it happen. |
Banned
Henry,
You still didn't explain that blue stuff. By that I mean why you left it there. Looks tackey after all that good work. Last edited by snowman; 12-08-2004 at 09:36 AM.. |
The layout dye is easy to remove.
http://www.dykem.com/Products/MarkingSystems/RemoversCleaners/rmvclnr.htm
John Dougherty Dougherty Racing Cams |
BLUE STUFF !!! OH NO
Snowman
With your eye for detail, perhaps you belong in Ohio tracking the recount. It would be about as useful as your critique of the unsightly " blue stuff".
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Friend of Warren
Henry you coming on here just to respond to an ignorant remark says a lot to me about your integrity. Those are some nice looking heads and the specs aren't so bad either!
Kurt V No more Porsches, but a revolving number of motorcycles. |
blue stuff. brilliant.
how about a party? i have the tar and feathers and henry has the blue stuff. anybody got a nice rail?
