Talking Let's Play - Predict the HP Game!
OK... folks... it's "let's play the predict the HP game"
The prize for the person that guesses the closest peak hp SAE Corrected on a DynoJet Rear Wheel HP), without going over wins a full tank of gas on me! (22 gallons of pump gas... that is... at $2.75 per gallon paid to the winner ... round to $60.00US)
I will be dynoing this car on a DynoJet 248C chassis dyno next week and will be posting the dyno chart results.
'82 105k SC engine with the following mods:
1. Re-Ring K&S pistons with Aluisil Cylinders 9.3:1 compression
2. 24 new head studs/barrel nuts...
3. New valve springs, valve job, valve stem seals
4. New timing chains, timing chain guides, timing chain tensioners
5. New WebCam (not welded) 20/21 cams, new rocker shafts, new rockers, new elephant's foot adjusters and all hardware...
6. New Genuine SSI headers
7. New Custom 321 Stainless 2 in / 2 out muffler by "mb911 (Pelicanite Member)"
8. New 40mm PMO Carbs/PMO manifolds/PMO linkage, & 36mm Venturis
9. Rebuilt Euro Distributor, Vacuum Advance Removed, converted to full mechanical advance, and recurved by International Auto Electric
10. Stock 34mm '82 SC port dimensions, stock exhaust port dimensions - no cylinder porting
11. All new seals/gaskets along the way...
In short... this is a bone stock rebuilt '82 SC engine with PMO's, 20/21 Cams, SSI Headers, 2 in/2 out muffler, and a mechanical advance recurved distributor.
Basic stuff...
So... what's your guess? Post 'em here!
TonyG
Old 11-01-2004, 10:16 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
peak hp at the wheels i take it. i might be way off here but here goes, 231.6 rwhp
74 911s neverending story. two feet and a jetta for now.
Old 11-01-2004, 10:57 PM
Porschekid962
Just corrected my post... good eye..
The contest is for the closest to the peak Hp, SAE corrected, Rear Wheel HP, on a DynoJet.
Sorry.... slight oversight (can't belive I slipped up on this one... :-)
TonyG
LSx 951 with 997 Cup Suspension - vision944.tonygarcia.org
3.6L 911SC - www.tonygarcia.org/911SC
Old 11-01-2004, 11:03 PM
jluetjen's Avatar
What size venturi in the carbs???
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 11-02-2004, 05:21 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I'll take a stab at it and say 200 at the wheels. Hopefully you'll find more power though.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-02-2004, 06:15 AM
Glenn from Denv's Avatar
214
_______________
Glenn from Denver
94 964 3.8 RSR
Old 11-02-2004, 06:36 AM
rdane's Avatar
Old 11-02-2004, 08:49 AM
jluetjen (and all)
...:::FURTHER DETAILS :::...
Venturi Size = 36mm
TonyG
Old 11-02-2004, 08:57 AM
No Expert
jgparker's Avatar
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 11-02-2004, 09:22 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
210
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 11-02-2004, 09:51 AM
jluetjen's Avatar
hmmm....
My guess is...
* 203 HP at the crank
* 172 RWHP
John
'69 911E
Old 11-02-2004, 10:15 AM
rdane's Avatar
John should that be 172.55
Here are some other dynojet numbers all taken the same day.
'79, mods are SSIs, Dansk 2 in and 2 out and a Webcam 20/21.
182 hp and 170# of torgue
'79, mods 1in/2 out Flowmaster.
168 hp and 162# of torque
177.1 hp and 161.8# of torque with SSIs
'81, mods SSIs with a OEM 2 in/ 1 out.
159 hp and 169# torque
'83, mods '73 OEM exhaust, Triad 2in and 2 out muffler and a Webcam 20/21 grind, 9.5:1 compression.
173hp and 174# of torque.
Start at 180/183 add 8 for the compression change and 5 for carbs and you are at 193/196...but I want t be under so 191
So far the best and most consistant numbers I have seen with the 20/21 or 964 cams have been 190/195 rwhp. Be fun to see how a carbed car does on the dyno.
Tony a question for you? Why the 20/21 cams with carbs?
Old 11-02-2004, 10:17 AM
BURN-BROS's Avatar
189
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-02-2004, 10:59 AM
rdane
I hope the carbs are worth more than 5hp! :-)
I selected the 20/21 cams, after reviewing several dyno sheets, because they seemed to provide a very broad smooth power band in the rpm range supported by the 34mm port heads.
Also, I wanted a cam selection that Richard at PMO had previously setup his carbs for in order to get the carbs calibrated as easily (cheaply) as possible (it's a fortune going back and forth with 6 of everything...).
TonyG
Old 11-02-2004, 11:06 AM
jluetjen's Avatar
Thanks rdane for the offer, but I think that I'll stand with the round number. Increasing the decimal places will just increase the chances that I'll go over.
It'll be interesting to see what the final numbers are and why. I'll reserve comment until then.
John
'69 911E
Old 11-02-2004, 11:18 AM
rdane's Avatar
Thanks Tony. Knowing how the PMO's should be jetted is worth a bunch. Not telling you anything new, the 20/21 cams (I love the broad torque band of mine in both the old 3.0 and the new 3.4 CIS) will be the limiting factor in your new 3.0.
I am very interested in seeing where you car dynos out and the dyno sheets for the curves. Please keep us posted.
cheers,
Dane
Old 11-02-2004, 11:40 AM
rdane
I'm limited by the piston-to-valve clearance issue of the stock pistons.
I think, and I'm not sure, that there are more agressive cams that will work with my stock pistons... but I figured I'd start out with the 20/21's, see how the thing dyno's out, then go from there depending on what the dyno chart looks like.
TonyG
Old 11-02-2004, 01:39 PM
jluetjen's Avatar
Historically rdane and I have agreed to disagree on some things -- and this may be one of those times -- or not! It's also been recorded that on some things we're in violent agreement.
We'll see after the numbers get posted.
PS: Boy, it sounds like I'm talking about the election -- doesn't it!
John
'69 911E
Old 11-02-2004, 02:17 PM
rdane's Avatar
Sorry Tony, I need to be more attentive to your build sheet. Didn't realize you reringed your OEM CIS pistons, of course that would limit your cam profile. In turn cams limit engine output.
For my engine the decision to stick with CIS outlined my engine build by limiting cam and then limiting my piston design. It would seem that by choosing to rering your CIS pistons you outlined your rebuild by doing that.
This was Superman's '83 that was reringed and CIS.
"83, mods '73 OEM exhaust, Triad 2in and 2 out muffler and a Webcam 20/21 grind, 9.5:1 compression.
173hp and 174# of torque."
BA (page 151) shows a 3.0 with 40 Webers, early exhaust and a stock muffler (on an engine dyno I assume) as 210hp and 200# of torque.
BA noted a 10hp for the addition of a set of carbs over a CIS system but that includes a cam profile to match.
"violent agreement"....that is a new one for me
I just enjoy keeping track of the different engine profiles and how people decided on what they built.
Old 11-02-2004, 02:46 PM
Rob Channell's Avatar
I'll guess based on the size in cubic inches of the next size up factory motor. (3.2 Carrera -> 3.2 liter-> 192 cubic inches)
umm.....I'll guess 192 hp at the rear wheels.
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 11-02-2004, 07:26 PM
