187
1971 Porsche 911 T Targa
Old 11-12-2004, 07:54 PM
drag racing the short bus
dd74's Avatar
180 rwhp.
The Terror of Tiny Town
Old 11-12-2004, 11:36 PM
...::: UPDATE :::...
Engine Installed Photo
Car is running rich with 150 main jets according to my "narrow band" a/f gauge (temp setup just to check things out).
Carbs are synchronized, car is running great. Pulls hard to 6500 rpms, idles great, very nice throttle transition/response.
MB911's muffler makes all the right noises/sounds...
I think I'm either going to go to 38mm chokes or 140 main jets (I'll have to consult Richard at PMO for advise).
I've had a "slight delay" in getting this car tuned and on the dyno as my wife had a baby boy last Monday (our 3rd boy!).... But I'm back on track :-)
Here's a pic:
TonyG
Old 11-14-2004, 08:42 PM
rdane's Avatar
Coingrads on the new baby! Seems like you should name him Carrera or something
Cars looking good too.
Old 11-15-2004, 08:38 AM
jluetjen's Avatar
Hey!!!! No fair changing the choke size until you report the HP numbers!!!!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 11-15-2004, 02:41 PM
jluetjen
>>>Hey!!!! No fair changing the choke size until you report the HP numbers!!!!<<<
Agreed. If I change the choke sizes, it will be on the dyno after I dyno the 36mm chokes.
I was just reporting my findings thusfar....
BTW: What do you think about 38mm chokes on this mild combo?
TonyG
LSx 951 with 997 Cup Suspension - vision944.tonygarcia.org
3.6L 911SC - www.tonygarcia.org/911SC
Old 11-15-2004, 02:55 PM
jluetjen's Avatar
I don't think that it will make a big difference in your top-end HP given that your ports are 34 mms -- and thus gating the airflow. Larger venturi may cost-you some low-end driveability - or not. It's an easy change to make while you're on the dyno. So only testing will tell.
John
'69 911E
Old 11-15-2004, 03:29 PM
dd74's Avatar
TonyG
Ummm...no rash decisions until you've gotten used to late-night feedings.
Seriously, given the rather mild condition of your engine, I think 38mm chokes would probably hurt your low-end torque. It all depends where and how you drive your car.
jluetjen's Avatar
After checking my numbers, I agree with dd74 -- I think that the larger chokes will hurt your low end driveability some. The gas speeds through the venturis isn't that high even with 36 mm venturis.
John
'69 911E
Old 11-15-2004, 03:44 PM
The reason I ask about the 38mm chokes is because when I used to build and race Datsun 510/240Z engines, I used 36mm chokes on 400cc cylinder setups (example: L16 = 1600cc - 400cc per cylinder) which was about right for a 3500rpm-7000rpm setup.
The 3.0 SC engine is 500cc per cylinder yet I'm setup with 36mm chokes....
Given this, isn't 38mm chokes more appropriate?
Right now the power is very linear from 1000rpms up through 6500rpms.
TonyG
Old 11-15-2004, 04:10 PM
jluetjen's Avatar
Only if the venturi are gating the intake system. Keep in mind that your intake ports downstream of the carbs are 34 mms.
John
'69 911E
Old 11-15-2004, 04:15 PM
jluetjen
>>>Only if the venturi are gating the intake system. Keep in mind that your intake ports downstream of the carbs are 34 mms.<<<
Uh... yeah. Time to put my thinking cap back on :-)
dumb question (especially when you know the answer)
TonyG
Old 11-15-2004, 04:18 PM
jluetjen's Avatar
Is this off of the "pants dyno" or the roller dyno?
John
'69 911E
Old 11-15-2004, 04:34 PM
jluetjen
That would be the seat-of-the-pants DynoJet :-)
(perhaps after coming from turbo charged cars everything feels linear :-)
TonyG
Old 11-15-2004, 04:44 PM
KobaltBlau's Avatar
which would mean you have numbers ... ?
Andy
Old 11-15-2004, 05:05 PM
KobaltBlau
No numbers yet. The seat of the pants dynojet is my butt. :-)
I do have numbers for my old 944 turbo, but it's not relevant here...
TonyG
Old 11-15-2004, 05:07 PM
No Expert
jgparker's Avatar
I think you have to take the top of the carbs off, and remove the aux venturie to change the chockes on Webers. I've never been able to do that quickly, and I'm too cheap to do that while on the clock at a dyno.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 11-15-2004, 05:27 PM
dd74's Avatar
So...any word?
Old 11-16-2004, 04:02 PM
rdane's Avatar
Originally posted by rudy
I have a 69T with a 78 3.0 I got from Elombard. I installed webbers insted of the cis and ssi's with a flowmaster. The car made 186 at the wheels through a 901 trans. Does this sound like a good number? I had some popping in the higher rpm's not sure if timing is spot on or the carbs.
78 3.0 with webbers and ssi's dynoed today
Old 11-16-2004, 04:15 PM
dd74's Avatar
What do you bet that 187 is a bit lower considering the intakes on an '83 are smaller than on a '78?
Old 11-16-2004, 04:23 PM
