Question 911 main bearings
I have a '78 3.0 case that needs align-bored. The crank is stnd., however the case side will most likely be .25mm oversize after the bore. Where can I get bearings, and at what cost?
Old 11-04-2004, 01:57 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Dealer and they are not cheap.
Wholesale is about $475.00
Good luck
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-04-2004, 05:50 PM
Irrationally exuberant
ChrisBennet's Avatar
What's cost to resize the case back to standard?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-04-2004, 05:54 PM
About $450 plus std bearings. $225 ?
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2004, 08:15 AM
Sounds to me that he'd be save money by having the case resized instead of line bored.
-Chris
Old 11-05-2004, 10:50 AM
Thanks to all that have replied so far. I since learned as Henry Schmidt suggested, that the dealer can order the bearings. Get ready for this!, $1,239.00. There's a chance however, that I can get the machine shop to pay for them; as there is evidence of the case been mis-matched.
As far as shaving the case halves; I'd be nervous about all the other ramifications like intermediate shaft bosses, piston clearance, and I'm not sure what else.
Old 11-05-2004, 12:17 PM
The machine shops that resize these cases take all of your concerns into account. [Remmeber we're talking about a few thou not a 1/4 inch.]
We do and I'm certain the Competition Engineering and Ollies do to.
If you have a favorate machine shop that specializes in Porsche machine work, just ask.
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2004, 12:45 PM
Did they have #8 or nose bearing in the csae when they torqued it together to check it ?
Old 11-07-2004, 08:38 AM
Thanks for your advice Henry; the case is been hand delivered to Ollie's on thurs.
Old 11-08-2004, 02:50 PM
