Still Doin Time
asphaltgambler's Avatar
Talking Half-Mooning lower cyl sleeves
Saw in Waynes book about 'half-mooning" the lower cylinder skirts to aid in piston down/out air flow. Can anyone tell me if this is really beneficial on a performance street engine? If so, what are the dimensions of the cut away and locating points??
Old 11-22-2004, 12:41 PM
Irrationally exuberant
ChrisBennet's Avatar
The effectiveness of airflow mods like this are open to debate. Like someone pointed out, you don't see these mods on any Porsche race motors. I think it was Henry Schmidt who wrote about this. (Do a search.)
On a 3.2L motor the cylinder only protrudes past the inside of the case 1/10".
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-22-2004, 01:24 PM
Probably about the same as a .010 decrease in the "squish" area.
-Andy
Old 11-22-2004, 01:28 PM
350HP930's Avatar
Short skirt pistons need all the cylinder they can get. I would not think there would be enough benefit to justify compromising the cylinder.
Old 11-22-2004, 05:23 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Here's what Ollie's Porsche Machining did to mine on my 3.2 to 3.5 Motronic conversion. They said it was a good idea to do if the case is being boattailed as well. Call up George or Ike at Ollie's, they both have been doing this a long, long time.
It cost me $80 for this service.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-22-2004, 06:37 PM
Nitrometano's Avatar
look cool!!
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 11-23-2004, 02:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally posted by Wayne at Pelican Parts
Not worth it for a street motor...
-Wayne
I agree with Wayne, only I would take it one step further. The cylinders on a 3.2/ 3.5 conversion 100mm are so thin that I think removing material is a mistake. 100 cylinders split more often than they should. Keep the material for strength if nothing else.
BTW: ask George for a dyno sheet that shows any benefit from this modification. My guess, they won't have one.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-23-2004, 05:26 PM
I guess my home-brewed motor is doomed!
Ralph
Old 11-23-2004, 08:13 PM
