swackdog's Avatar
Where Do These Wires Go?
I am putting my 81 911SC back together after a top end rebuilt. I've got all of the wires connected except these two - one brown, one red/white stripe. I cannot find anywhere to plug them in. Any suggestions? Should these connected to anything?
Old 11-23-2004, 06:58 PM
al lkosmal's Avatar
Those appear to be the wires that run to the heater blower motor in the engine compartment.
RGruppe #669
http://www.x-faktory.com/
Old 11-23-2004, 10:09 PM
Try not, Do or Do not
Henry Schmidt's Avatar
From memory mind you.
The wires to the heater blower are brown and yellow w/ black tracer.
The wires you are asking about go to a thermal vacuum switch. I am just guessing but if I remember correctly it has to do with enrichment vacuum to the warm-up regulator.
If some one out there has a wiring diagram perhaps they could check for you.
Good luck.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-24-2004, 07:51 AM
swackdog's Avatar
Henry,
You are correct. The wiring diagram in the Bentley manual show these colored wires going to the warm up regulator and the supplementary air valve. Now I just have to find it. Thanks.
Jim
1981 911SC Red/black
Old 11-24-2004, 08:56 AM
Unregistered
sammyg2's Avatar
HMMM, I don't have one of those.
Am I supposed to have one on a 1980 SC, and if so where is it supposed to be located?
Thanks.
Old 11-24-2004, 11:19 AM
follow the vacuum hose off the top of the WUR to find the thermo-valve. if you have one, it hangs off the left side of the mount for the heater blower motor. if your engine is supposed to have one and it's been removed, that may be why it's cold blooded and cranky on a cold start/run, and you did'nt really have to knock down the pin in the WUR after all.
206 637 4071
Old 11-24-2004, 11:32 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Remember, everone else who has replied knows better than I, but are those plugs or solid ends? For whatever reason, they look like the back-up light wires to me.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 11-24-2004, 12:36 PM
