Limbo
Slider79SC's Avatar
Will these fit on my 3.0L
No response from the technical forum so I thought I would post here.
Will 993 heat exchangers fit a 3.0L SC motor?
I know the passenger side exchanger will need to be cut at the ports, rotated and re-welded but I was wondering about the spacing between the ports?
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 12-28-2004, 01:53 PM
Limbo
Slider79SC's Avatar
Wayne,
I understand what you are saying but, if the 993 passenger side exchanger had the three inlets that mount to the heads cut off and rotated then re-welded, wouldn’t they then fit?
I know that guys have done this on 964 motors, so if they can do that for the 964 motors, then wouldn't the same exchangers fit on a 3.0L?
Do SSI's from a 3.0L fit on a 964 motor, I know the tube size wouldn't be correct for best performance but will they bolt up?
What I am wondering is if the spacing for the exhaust ports to bolt on the exhaust (headers/heat exchangers) is the same for a 3.0L, 964 motor and a 993 motor?
Old 12-28-2004, 05:31 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by Slider79SC
Wayne,
AFIK SSI's will fit on a 964 motor. Exhaust port spacing is the same for all of those.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-29-2004, 06:17 AM
Limbo
Slider79SC's Avatar
Thanks guys,
Let the new project begin.. MUHAHAhahaha
Old 12-29-2004, 06:48 AM
