H.G.P.'s Avatar
Page 128, column #2 What O-ring?
In Wayne' book page 128, I'm assuming the O-ring mentioned here is for the no. 8 bearing o-ring, correct? (Asking because this is mentioned right after slipping on the flywheel seal.)
Also, there's no o-ring on the flywheel seal end is there? Thanks!
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-28-2004, 02:03 PM
Super Moderator
cstreit's Avatar
Correct, there is no o-ring on the flywheel seal end.
The only o-ring on the crank is the one that goes around the #8 bearing. Be sure to lube that o-ring slightly so it doesn't tear when you mate the case halves...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-28-2004, 06:08 PM
H.G.P.'s Avatar
Thanks for the heads-up on that o-ring Chris. I nearly forgot about it in visualizing mating the halves, with the other stuff....o-rings case through bolts, sealing curing time, rod/chain holders. etc.,............
1969 911 E Coupe
Old 12-28-2004, 11:16 PM
Author of "101 Projects"
Wayne 962's Avatar
Bottom right side of page 128 - "Without the o-ring installed on the bearing,lay it in the engine case..."
Bottom left side of page 128 - "Install the o-ring onto the bearing"
Yes, both statements apply to the o-ring on the nose bearing. Make sure you get the proper one for your car - people have had trouble using the later, thicker style one with the earlier bearings...
-Wayne
Old 12-29-2004, 12:29 AM
