rdane's Avatar
3.6 mods?
I have a 964 case, heads, P&Cs, rod, crank and ignition. All the motronic off 95 is there with the rest to get the engine up and running.
What would you do while putting the engine back together to maximise the relaibiltiy and power.
I want more power that the 964s originally put out. 270 at teh wheels seems easy for the '95. What needs to be done to bump the base 964 engine to '95 levels or better while maintaining reliability.
Engine is apart and being totally rebuilt so the only costs are parts, not labor.
Old 01-01-2005, 09:14 PM
Author of "101 Projects"
Wayne 962's Avatar
The problem with Motronic units like these is that you can't make any major changes without modifying the maps in the chip. You can try running a slightly hotter camshaft (there are a few, but I can't remember them off the top of my head). I wouldn't recommend bumping the compression on these, as I think they ran about 11:1 in 1995.
The best thing for the 3.6s would be to run hotter cams and modify the pistons to fit. But then you will run into problems with the stock Motronic (both programming and fuel reversion issues below 3000-4000 RPM). A good way to avoid this is to run a TEC-3 or to run PMOs. Eade is building his RSR replica with PMOs. I don't think he's swapping pistons or cams though (future project maybe). Note that doing all of this will cause problems with smog...
-Wayne
Old 01-01-2005, 11:14 PM
Bill Verburg's Avatar
I am assuming that you have a '95 993 engine?
The casting on the case is 964*****
If so;
top end, 993ss cams or maybe even a tad hotter work great w/ stock Motronic, RS valves(52/43mm) Ti would be nice but not needed for a mild street engine, some tidying of the ports, stock 993 valve train is good to ~7800 so unless you want to twist it past there more exotic springs etc. aren't needed. Use US sourced Phosporus-Bronze guides.
Get a chip burned on a dyno.
Headers will depend on heat requirements, here are some really nice ones, 1.75" OD max unless going racing. If heat is needed B&B are ok.
Don't forget the bottom end, Arp or Raceware rodbolts
Bill Verburg
Old 01-02-2005, 01:04 PM
rdane's Avatar
Sorry for the confusion and thanks for the help.
Engine case and the lower end is a 964 3.6 from 1992. The rest of the engine (induction, twin plugs ect) comes from a '95 that was stripped and went to electromotive and PMOs.
I was thinking ditch the early 3.6 crank was all it would take to have a '95 3.6 if everything else is the same spec. Are the rods the same on the 964s and the '95 993?
What I have now is a miss match of a mid year 964 3.6 and the induction and some of the parts from a '95 all in boxes. I was wondering if there is anything to change out or replace for better performance as we do the rebuild?
Old 01-02-2005, 02:09 PM
964 and 993 rods are not interchangeable.
You can put a whole 993 bottom end(crank, rods, p/c) into the 964 case. The 993 crank is much more desireable.
What heads?
If you have 993 then you need to decide whether to stay w/ hyd. lifters or switch to mech., for mostly street use I would keep the hyd. You will also want to backdate the cam drives to 964 parts.
For '92 964 heads just clean up the ports.
Bill Verburg
Old 01-02-2005, 03:41 PM
you want to stay away from the 964 rods with the smaller rod bolts
993 rods use the small bolts as well, the rods are stronger and h/d version as well as aftermarkets are availble but generally not needed for street use.
Do replace any of the small rod bolts on any engine w/ ARP or Raceware.
Bill Verburg
Old 01-06-2005, 11:31 AM
Wayne 962's Avatar
Right - although the problem doesn't seem to show up as much on the 993s - not sure why...
-Wayne
Old 01-06-2005, 11:12 PM
VincentVega's Avatar
Timely thread. I have a 94 3.6 w/ rs cams. Is ~7800 a safe redline for an otherwise stock motor?
Old 01-07-2005, 09:44 PM
Wayne 962's Avatar
I'd say 6500 is a safe red line, and 7800 is too high...
Remember, this is a latent failure. An over-rev may not cause a failure of the rod bolts when it happens, but it may weaken them. Repeatedly revving the engine high will cause more damage each time. Then, repeated normal use of the engine may cause them to become loose and fall off or break. This is my theory on the subject, and one of the reaons why I like a little bit of red Loctite on rod bolts.
-Wayne
Old 01-07-2005, 10:39 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Chris, just out of curiousity, why would you rev the motor to 7,800 rpm? If it is basically stock with just RS cams, I seriously doubt that it is making power anywhere near that rpm.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 01-08-2005, 08:02 AM
That is about the limit for a stock valve train, but the bottom end will pop well before that unless it is beefed up.
Not sure what RS cams you have RSA is the same as regular as are the Cup cams.
W/ those cams there is no reason to rev past the very low 6k range.
Bill Verburg
Old 01-08-2005, 02:51 PM
Thanks guys, I was thinking ~6k was about it, just making sure. The car has a 7.3:1, so 6k comes reall quick.
Old 01-09-2005, 06:53 PM
Wer bremst verliert
JohnJL's Avatar
Don't forget the LWF
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-10-2005, 07:32 PM
All 3.6 t/ps will use a light weight flywheel compared to stock 964/993
Bill Verburg
Old 03-10-2005, 08:05 PM
