Irrationally exuberant
Here a couple of wild ideas:
- I've seen the air injection holes welded shut. Maybe part of the "plug" fell out? - It looks like aluminum but is it? Could it be epoxy perhaps? - Maybe it didn't come from the motor at all. Hey, I did say they were wild ideas.. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks guys.. I'll get some other photos tonight and also take some measurments.
It is metal. I tried to see if the rough edges were some sort of sealer but the "plug" is all metal with some type of paint/coating. The top is slightly rounded (crowned). Cheers and thanks
Kerry (Back on the road, sort of) 914-6 in the Werks |
Crowned from the too long bolt that pushed the blocks casting out making your ruff punched plug.
My $400 PoMansPorshe best running/uglyest 914 runing the streets of Sarasota Fl daily!! |
Author of "101 Projects"
Did you look at the cam towers like I suggested?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I did but to be honest I don't know where the plugs for the cam tower are?
I have been looking all over the heads, towers, cam tensioner housings..etc. If you can easily tell me where the plug is you are talking about that would help. Thanks agian and I have some better photos which I will post tonight Kerry
Cam towers have a plug, This plug seems alittle bigger and not as smooth.
Looks like I will be just crossing my fingers Thanks guys
Kerry (Back on the road, sort of) 914-6 in the Werks Last edited by Va914; 01-08-2005 at 02:04 PM.. |
Now in 993 land ...
Is this bit steel, aluminum or magnesium? You can at least see if it is magnetic? JB weld or other epoxies may be metal filled too?
There isn't much you can do, nobody seems to know that this is the plug from hell that requires complete engine disassembly. ![]() Good luck! George |
It is not a PLUG!!! It is the bottom of a threaded hole that was pressed out by too long of a bolt being screwed into the Block. Split the block to find it but I would just Run It.
faster than I once was...
quote from snowman: "So far everyone agrees that this dosen't look like a normal plug but is resembles one close enough that no one can say it isn't.
This could make sense. A proper plug would not have fallen out to begin with, so the fact that it may have fell out and dosen't look quite right are consistant. Measure the plug diameter exactly and post the results. Should be very close to a known plug dimension if it is one." Is this from the same man who previously commented about someone else's spelling mistakes??? LOL
~Dave |
Banned
I don't think so.
