Irrationally exuberant
ChrisBennet's Avatar
Here a couple of wild ideas:
- I've seen the air injection holes welded shut. Maybe part of the "plug" fell out?
- It looks like aluminum but is it? Could it be epoxy perhaps?
- Maybe it didn't come from the motor at all.
Hey, I did say they were wild ideas..
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-04-2005, 07:31 PM
Va914's Avatar
Thanks guys.. I'll get some other photos tonight and also take some measurments.
It is metal. I tried to see if the rough edges were some sort of sealer but the "plug" is all metal with some type of paint/coating.
The top is slightly rounded (crowned).
Cheers and thanks
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 01-05-2005, 04:25 AM
Crowned from the too long bolt that pushed the blocks casting out making your ruff punched plug.
My $400 PoMansPorshe best running/uglyest 914 runing the streets of Sarasota Fl daily!!
Old 01-06-2005, 04:03 AM
Va914's Avatar
I did but to be honest I don't know where the plugs for the cam tower are?
I have been looking all over the heads, towers, cam tensioner housings..etc.
If you can easily tell me where the plug is you are talking about that would help.
Thanks agian and I have some better photos which I will post tonight
Kerry
914-6 in the Werks
Old 01-07-2005, 04:15 AM
Va914's Avatar
Cam towers have a plug, This plug seems alittle bigger and not as smooth.
Looks like I will be just crossing my fingers
Thanks guys
914-6 in the Werks
Old 01-07-2005, 03:59 PM
Now in 993 land ...
aigel's Avatar
Is this bit steel, aluminum or magnesium? You can at least see if it is magnetic? JB weld or other epoxies may be metal filled too?
There isn't much you can do, nobody seems to know that this is the plug from hell that requires complete engine disassembly.
Good luck!
George
81 SC (sold)
Old 01-07-2005, 10:20 PM
It is not a PLUG!!! It is the bottom of a threaded hole that was pressed out by too long of a bolt being screwed into the Block. Split the block to find it but I would just Run It.
Old 01-08-2005, 02:12 AM
faster than I once was...
FastDave's Avatar
Send a message via Yahoo to FastDave
quote from snowman: "So far everyone agrees that this dosen't look like a normal plug but is resembles one close enough that no one can say it isn't.
This could make sense. A proper plug would not have fallen out to begin with, so the fact that it may have fell out and dosen't look quite right are consistant.
Measure the plug diameter exactly and post the results. Should be very close to a known plug dimension if it is one."
Is this from the same man who previously commented about someone else's spelling mistakes??? LOL
~Dave
Old 01-08-2005, 01:46 PM
Banned
snowman's Avatar
I don't think so.
Old 01-08-2005, 05:23 PM
