what can i do with 964 bits?
got some 1990 964 bits-crank, rods, pistons, cylinders, heads, cam carriers,twin plug dizzy, inlet plus pipework.
are any of these bits interchangable with the earlier engines? (SC/930 etc) Im building a 930 engine myself so im going to use the 964 cams. I was going to use a Carrera inlet for my efi conversion, could I use the 964 inlet instead? also, what are these bits worth? Thanks blokes Andy
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
bummmmmp
The guys here sometimes use the 964 distributor to do the twin plug thing.
David Duffield (old english name) Last edited by Oldporsche; 02-02-2005 at 06:48 PM.. |
thanks David Duffield!
Andy
Andy do you still have the distributor?
Eric Hood |
The rods will also work in a 3.2 or 3.3....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
no, sold im afraid.
cheers for the info jeff
In fact, I would bet the rods have the 930 part number on them......
My spare set does! Cheers
Ive got an idea,
build the 3.6 pop that in, remap it to 315bhp save yourself £15k on your fancy early engine and have something that is reliable, goes like stink and doesnt let you down Porsche - there is no substitute (for substituting with a 3.6!) |
Remap? I assume you mean the motronic chip? It takes way more than a new chip to get 315 hp out of a 250hp 3.6. A 315hp 3.6 is an expensive motor to build!
Cheers
