what woul you use
to clean a 2.7RS mag case ?
Philippe |
Soap, Hot water, and engine degreaser.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Philippe
Sometimes you need to be a bit harsher, I made a 'spit' out of a piece of 10mm steel rod but hacksawing a slot in the end, I put this in the chuck of a flexible drive off a power drill and in the slot you put bits of scotchbrite type pads, You can also round of the end of the rod with a file, This is great for getting the crusty bits off HTH Neven |
Philippe
Oops meant 'split' not 'spit' |
