Gon fix it with me hammer
rsr seals or curil-t
guys , Wayne's book says use the RSR seals for the rocker arms
but also in the book , several other seals get the added treatment of Curil-T... what about using Curil T on the rocker arms themselves, and no rsr seal?? wouldn't that work??? or sillicone sealant , the stuff also used on the trough bolts? wouldn't that make an oil leak free camhousing?? or am i just beeing to creative in my thinking here?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Irrationally exuberant
The rocker shafts (with or w/out seals) need to go in dry. You'll need to wipe out any oil in the rocker arm bushing as well as cleaning the rocker shaft bores. The rocker shafts are expanded by the pinch bolts and the only thing holding them in place is "the miracle of friction".
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
right , bad idea then...
what about JB Weld? .. just kidding
I'm putting shafts in now, using the rsr seals. Curl-t would smear in there making a mess.
But what about something like Yamabond five, AFTER the rockers are in? (Does anybody have an answer to my timing chain question
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
check your thread
It's important to have scratch free rocker shaft bores if you want to avoid leaks. Here's what we're dealing with:
To avoid scratching the bores where the rocker shaft seals you want to clean the bore before you remove the shaft. The rocker shaft sits flush with (or even sticks out a little) one side of the rocker shaft bore (A). The other end of the rocker shaft sits in a bore that has a lot of exposed area and that bore tends to get dirty and corroded (B). If you remove and install the rocker shafts from the "A" side you avoid pushing the shaft over the rough and possibly dirty surface found at the "B" end. I don't like the idea but I know someone who seals the exposed end with some silicone or RTV after the shafts are installed. I guess the worst that can happen is that some falls off and drops down the spark plug hole. -Chris
yes something can fall off and get in the spark plug hole, but realistically , the same can happen if you have a leak , the oil and grime , just as well can end up in the hole.. RTV or Sillicone, neither of them pose a real threat , not even if they would fall in the spark plug hole( while replacing plugs for example) cause it would simply burn up , at worst you're looking at a maybe 2 gram piece of relatively soft compound at best is keeps the camhousing seriously leak free....
The only way to make the rocker shafts seal is to make sure the bores in your camboxes are as scratch free as possible. If there are any deep marks then, the ONLY thing to do is replace the camboxes! Provided the bores are ligfhtly scored then you will need to fit RSR rocker shaft seals, make sure your shafts are correctly fitted as per the diagram in previous post, and polish all contacting surfaces as well as possible. This should fix the problem, remember, putting silicone or similar over the ends of the shafts is at best a temporary fix
Regards Mike www.spyderautomobiles.com.au http://spyderauto.wordpress.com http://www.facebook.com/#!/pages/Spyder-Automobiles/311683175539345 Spyder Automobiles, maintaining the integrity, building excitement! |
I used the RSR seals on my 87 turbo rebuild. I wiped the bores as clean as possible and installed the shafts with a very small amount of engine lube to prevent cutting the seals during installation. 2000 miles after rebuild and no leaks.
Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head |
