Licensed User
Shuie's Avatar
I bought the snap on tool to do mine. I could have double nutted them and been fine. The heat on the inside of the spigot is the key.
Old 02-18-2005, 05:15 PM
I am my 911's PO
'78 SC's Avatar
Chris,
I agree that too much torque here can be a bad thing; I used the air wrench as a way to lessen the lateral force applied to the stud while turning it. My impression is dilivar is brittle and doesn't take kindly to lateral movement.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 02-18-2005, 05:52 PM
Here's the pics of my stud removal tools.--- the struggle is much easier with the 1" wrench and the setup works nicely in the lathe for cleaning/polishing. I used a heat gun to heat the case and deal to the Loctite,as I was a bit wary of putting the gas torch on the magnesium.
Old 02-22-2005, 05:13 PM
Bob,
Very interesting, thank you for taking the time to take some pictures of your custom tooling. I still have not performed this operation yet, what are the possibilities of borrowing your set-up?
Best Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-22-2005, 08:35 PM
No problem, Alex, but I am in New Zealand!--- .There must be someone on here that will volunteer to turn up a bit of hex bar for you? I made one nut fairly long to get a good set in the lathe chuck, and the thin one because there is not much thread on the top of the studs. I used POR15 on the shiny shanks after cleaning them up. The case is a '77 ,7R --its a 911/85--and I believe all the studs were original factory installation, all are magnetic, so I dont think there were any Dilivar.--A bit strange that!
My other engine is a '76--911/84 and all the housings etc are
magnesium, but the '77 aparently inherited a lot of the 930
bits that year---- camchain housings, and rocker covers are all
alloy.
Bob
Old 02-23-2005, 01:41 AM
I started a new thread with this question, but is it safe to put a flame on a mag case?
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 02-23-2005, 04:46 PM
350HP930's Avatar
Yes, just don't use too hot of a flame.
Old 02-23-2005, 06:11 PM
