-   -   Any suggestions for removing my 911 case studs without the expensive snap on tool? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/206324-any-suggestions-removing-my-911-case-studs-without-expensive-snap-tool.html)
Determined 02-13-2005 11:49 PM
I'm certain the snap-on tool is the way to go but I've only found them in kits and I can't afford to buy the entire set. I'd like a used one or if anyone can offer an alternative that won't damage my case then I'm listening.
Thanks for your time and support.
Best Regards,
Alex
walt 02-14-2005 02:53 AM
I have a set of Cornwell's that use three cam like discs that bite into the stud. They worked, but had a tendency to slip. The collet type like Snap Tite is probably better. I think Pelican sells Snap Tite individually so you don't need to buy an entire set.
Rot 911 02-14-2005 05:58 AM
You can get the removal tool with just the individual collets direct from Snap On: Stud Removal Tool
safe 02-14-2005 06:12 AM
Can't you use a small pipe wrench?
Groesbeck Hurricane 02-14-2005 06:13 AM
Your regular Snap-On guy will order just the parts you need. There are also some removal tools sold by Harbour Freight Tools, but they don't work as well, and Sears sells some but I have no history with them: http://www.sears.com/sr/javasr/search.do?keyword=Bolt+Out&displayTarget=searchres ults&vertical=TOOL&adCell=P10&BV_SessionID=@@@@028 4752186.1108390130@@@@&BV_EngineID=ccffadddlggeklf cehgcemgdffmdggg.0
ChrisBennet 02-14-2005 09:31 AM
I use the ones sold by Baum Tools. See my posts on this thread Much cheaper and less clunky than the SnapOn ones.
-Chris
cstreit 02-14-2005 09:50 AM
I have the snap-on tool, but I double-jam-nutted some when they were really tough and the tool slipped.
Use plenty of heat and steady pressure. A sharp motion when removing can snap them...
sammyg2 02-14-2005 03:43 PM
Heat up the case and you won't need the expensive tool.
I used mapp gas and double-nutted the studs (at least the 11 that weren't broken) with some extra nuts I had laying around, used a ratchet stype box end wrench, no problemo. One of the easier things I've done on this car.
PS on the broken stud I just used a regular ole vise grips to get it moving then switched to channel locks.
350HP930 02-14-2005 03:58 PM
Heat is your friend. Get the case around the stud hot enough to vaporise oil.
magic930 02-14-2005 07:40 PM
If you are discarding the studs then you can buy a cheap metric stud removal kit for $10 at your local auto parts store. It will completely destroy the threads but will get them out easily.
'78 SC 02-14-2005 08:24 PM
I lusted after the Snapon extractors but couldn't find a set at a reasonable price (even on ebay). I also needed a tool that could deal with the unthreaded remains of several broken studs. The Craftsman bolt extractors I described in this thread worked for me. Definitely use heat to soften the loctite and use an air wrench.
Bobboloo 02-15-2005 02:32 PM
Heat,heat,heat. The loctite bond releases with the appropriate amount of heat. I find heating the case very difficult at best to do. The aluminum or magnesium heat sinks. For me applying the torch at the point where the stud meets the case works best.
john walker's workshop 02-15-2005 04:19 PM
you just heat the case around the stud and in the spigot adjacent to the stud. keep tension on the stud remover tool and when the stud starts to move, keep the heat on a bit longer until it moves easily. heat the case, not the stud.
adomakin 02-16-2005 04:20 AM
two nuts and map gas worked nice for me
Andy
Determined 02-16-2005 07:41 AM
Gentlemen,
Thank you all for your valuable advice, I greatly appreciate it! I have learned a tremendous amount of knowledge from everyone's experiences.
Best Regards,
Alex
snowman 02-16-2005 07:47 PM
Thanks guys for finally getting the locktite/heat message, its the key to getting those seemingly really stuck studs out.
Bob Goding 02-16-2005 10:27 PM
To remove the studs from my 7R mag case, I found some 1"
hex steel bar and made up a pair of nuts, Drilled and tapped 10mm in the lathe and parted off. They clamp up nice and tight with an open end wrench and a socket. Cost me nothing ,[but I did have access to the lathe]. Then I used a heat gun to break the Loctite and had no trouble winding them out with the 1 inch open end .
I also used these nuts to chuck the studs in the lathe and clean them up with a bit of emery cloth. Came up nice,with no thread damage.
Determined 02-16-2005 10:31 PM
Bob,
I'm curious, do you have pictures?
Thanks for your time.
Alex
Ove 02-18-2005 04:14 PM
If the stud is broken (and long enough) you can make new threads on it, then jam two nuts together to get it out.
Here's one of mine
http://forums.pelicanparts.com/uploa...1108771940.jpg
cstreit 02-18-2005 04:53 PM
I'd recommend against using an air-tool as someone recommended above.. Steady pressure while heating is better (ala JW). THe shock from an air tool increases the chance of one snapping.
