LinkBack | Thread Tools | Rate Thread |
Any suggestions for removing my 911 case studs without the expensive snap on tool?
I'm certain the snap-on tool is the way to go but I've only found them in kits and I can't afford to buy the entire set. I'd like a used one or if anyone can offer an alternative that won't damage my case then I'm listening.
Thanks for your time and support. Best Regards, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
I have a set of Cornwell's that use three cam like discs that bite into the stud. They worked, but had a tendency to slip. The collet type like Snap Tite is probably better. I think Pelican sells Snap Tite individually so you don't need to buy an entire set.
Walt 82SC 3.0 81SC 3.6 |
Friend of Warren
You can get the removal tool with just the individual collets direct from Snap On: Stud Removal Tool
Kurt V No more Porsches, but a revolving number of motorcycles. |
Can't you use a small pipe wrench?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
JOT MON ABBR OTH
Your regular Snap-On guy will order just the parts you need. There are also some removal tools sold by Harbour Freight Tools, but they don't work as well, and Sears sells some but I have no history with them: http://www.sears.com/sr/javasr/search.do?keyword=Bolt+Out&displayTarget=searchresults&vertical=TOOL&adCell=P10&BV_SessionID=@@@@0284752186.1108390130@@@@&BV_EngineID=ccffadddlggeklfcehgcemgdffmdggg.0
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Irrationally exuberant
I use the ones sold by Baum Tools. See my posts on this thread Much cheaper and less clunky than the SnapOn ones.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Super Moderator
I have the snap-on tool, but I double-jam-nutted some when they were really tough and the tool slipped.
Use plenty of heat and steady pressure. A sharp motion when removing can snap them...
Unregistered
Heat up the case and you won't need the expensive tool.
I used mapp gas and double-nutted the studs (at least the 11 that weren't broken) with some extra nuts I had laying around, used a ratchet stype box end wrench, no problemo. One of the easier things I've done on this car. PS on the broken stud I just used a regular ole vise grips to get it moving then switched to channel locks. |
Heat is your friend. Get the case around the stud hot enough to vaporise oil.
If you are discarding the studs then you can buy a cheap metric stud removal kit for $10 at your local auto parts store. It will completely destroy the threads but will get them out easily.
David |
I am my 911's PO
I lusted after the Snapon extractors but couldn't find a set at a reasonable price (even on ebay). I also needed a tool that could deal with the unthreaded remains of several broken studs. The Craftsman bolt extractors I described in this thread worked for me. Definitely use heat to soften the loctite and use an air wrench.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
Warren Hall Student
Heat,heat,heat. The loctite bond releases with the appropriate amount of heat. I find heating the case very difficult at best to do. The aluminum or magnesium heat sinks. For me applying the torch at the point where the stud meets the case works best.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
you just heat the case around the stud and in the spigot adjacent to the stud. keep tension on the stud remover tool and when the stud starts to move, keep the heat on a bit longer until it moves easily. heat the case, not the stud.
two nuts and map gas worked nice for me
Andy
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Gentlemen,
Thank you all for your valuable advice, I greatly appreciate it! I have learned a tremendous amount of knowledge from everyone's experiences. Best Regards, Alex
Banned
Thanks guys for finally getting the locktite/heat message, its the key to getting those seemingly really stuck studs out.
To remove the studs from my 7R mag case, I found some 1"
hex steel bar and made up a pair of nuts, Drilled and tapped 10mm in the lathe and parted off. They clamp up nice and tight with an open end wrench and a socket. Cost me nothing ,[but I did have access to the lathe]. Then I used a heat gun to break the Loctite and had no trouble winding them out with the 1 inch open end . I also used these nuts to chuck the studs in the lathe and clean them up with a bit of emery cloth. Came up nice,with no thread damage. |
Bob,
I'm curious, do you have pictures? Thanks for your time. Alex
911 driver
If the stud is broken (and long enough) you can make new threads on it, then jam two nuts together to get it out.
Here's one of mine
Ove '77 911S targa |
Super Moderator
I'd recommend against using an air-tool as someone recommended above.. Steady pressure while heating is better (ala JW). THe shock from an air tool increases the chance of one snapping.
