Cylinder Identification
Can someone tell me if these markings identify the type of cylinder?(Nik/Alus)
TIA
Ken Martin
Old 02-17-2005, 07:04 AM
I'm no expert, but I learned recently that if you take a magnet and place it on the inside wall of the cylinder it will either attach or not. If it attaches or shows that it is magnetic it is likely to be Nik. Others with more experience can tell you more details. I hope it helps.
Best Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-17-2005, 09:39 AM
BURN-BROS's Avatar
3.3 turbo and should be nick.
3.0 turbo?
Does any other cylinders have no fins on the intake side?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 02-17-2005, 09:46 AM
Warren Hall Student
Bobboloo's Avatar
Wow. I've never seen anything like that. A cylinder with no fins.
The only markings I see is the number 5 painted on.
The other markings are for the cylinder head which indicate that it was made in Dec. of 77' so most likely for a 78' motor.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-21-2005, 11:56 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Looks like a 3.3 turbo to me, there's a pic in BA's book showing these cylinders. They only have fins on the bottom, not the top.
I'd be suprised if they're alusil, but the only definitive way (that I know of) to know is if you pull the heads and use a magnet.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-22-2005, 05:13 AM
thanks everyone.... I pulled them.. they're Nik, Mahle... it is a 3.3 tubo no fins on the top. I need to replace one, does anybody have a good one?
Thanks again
KM
Old 02-22-2005, 11:39 AM
