Cylinder Identification
Can someone tell me if these markings identify the type of cylinder?(Nik/Alus)
TIA Ken Martin
I'm no expert, but I learned recently that if you take a magnet and place it on the inside wall of the cylinder it will either attach or not. If it attaches or shows that it is magnetic it is likely to be Nik. Others with more experience can tell you more details. I hope it helps.
Best Regards, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
3.3 turbo and should be nick.
3.0 turbo? Does any other cylinders have no fins on the intake side?
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 02-17-2005 at 09:48 AM.. |
Warren Hall Student
Wow. I've never seen anything like that. A cylinder with no fins.
The only markings I see is the number 5 painted on. The other markings are for the cylinder head which indicate that it was made in Dec. of 77' so most likely for a 78' motor.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Looks like a 3.3 turbo to me, there's a pic in BA's book showing these cylinders. They only have fins on the bottom, not the top.
I'd be suprised if they're alusil, but the only definitive way (that I know of) to know is if you pull the heads and use a magnet.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
thanks everyone.... I pulled them.. they're Nik, Mahle... it is a 3.3 tubo no fins on the top. I need to replace one, does anybody have a good one?
Thanks again KM |
