Jeff Alton's Avatar
3.6 rebuild has begun!
Finally got started on the 3.6 rebuild for my 84. Should be fun!
And here is what happens when you are not careful rmoving wristpin circlips!!
Cheers, Jeff
www.turn3autosport.com
Old 02-24-2005, 09:05 PM
Ouch! Good luck on your rebuild, I am deep into my 3.2L rebuild myself. It's my first time ever, I couldn't help to notice that you have everything laying around. I recommend you get Wayne's book, it has great easy and inexpensive tips to help keep organized. It will help in the long run, trust me, I've learned the hard way myself.
Best Regards and good luck!
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-24-2005, 09:13 PM
Jeff Alton's Avatar
Thanks, this is the 4th rebuild, first 3.6. I have waynes book, factory manuals and a Bently as well. It does not look like that anymore. Everything is laying around as I had just taken the motor out of a crate and it was partially disassembled. All is neat and organized now!
Cheers, Jeff
Old 02-24-2005, 09:18 PM
Irrationally exuberant
ChrisBennet's Avatar
"Give blood, build motors" doesn't have the same ring to it as those "Give blood, play rugby" bumper stickers.
Don is also building up a 964. You might want to check out his thread First time rebuilder gaining momentum! if you haven't already.
Neat engine stand. I've never seen a "K" shaped one like that. Looks like a drip pan would sit on it nicely.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-25-2005, 03:10 AM
Jeff Alton's Avatar
Thanks Chris, I have checked that thread! A drip pan does fit very nicely in there!
Cheers, Jeff
Old 02-25-2005, 08:43 AM
addictionMS's Avatar
I just want to know what the hammer was used for...
looks good
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 02-25-2005, 09:06 AM
Jeff Alton's Avatar
I was wondering when someone was going to ask!! I used it to help open the crate that the motor came in and had not put it away yet!!
Jeff
Old 02-25-2005, 11:04 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Looking good Jeff. I guess it must be spring in Vancouver, eh?
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 02-25-2005, 11:08 AM
Jeff Alton's Avatar
Ralph, we have had 14 straight days of sunshine!! Pretty remarkable for up here! Not all that warm, but I am not complaining! Notice the Sleemans in the background?!?!
Cheers, Jeff
Old 02-25-2005, 12:46 PM
Cheers, Jeff
Yeah, so my parents gleefully tell me. We are the exact opposite right now. They are saying things are so bad up there they are considering water rationing again this summer? Does Grouse & Cypress have any snow?
Missed the Sleemans the first time, but now that I look I found it. Have you decided to keep it a 3.6L or are you going with some bigger P's and C's?
Ralph
Old 02-25-2005, 01:26 PM
Jeff Alton's Avatar
Ralph, the P/C set is going out on monday to get measured. If they are out of spec it is going to be 3.8 with 11.5 JE pistons. If they are in spec it will stay a 3.6. Not sure what cam to use as it has to pass emmission testing here without a cat. The 3.2 sailed through without a cat and 964 cams, any suggsetions? I would like to use DRCAMS as John (camgrinder) has treated me well in the past.
Thanks, Jeff
Old 02-25-2005, 06:11 PM
efhughes3's Avatar
Originally posted by ChrisBennet
[BI've never seen a "K" shaped one like that. Looks like a drip pan would sit on it nicely.
-Chris [/B]
K for Kanadian?
Glad to see your getting started. Keep us informed with words and pics as you go.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-25-2005, 07:38 PM
Jeff Alton's Avatar
Will do, on my out to the shop right now to remove the head studs!
Cheers, Jeff
Old 02-25-2005, 08:18 PM
Thanks, Jeff
Are you hoping that they are out of spec?
Ask John what cams to use, he would know the hot set-up for you. All my info is dated 10+ years ago, geez the hot set-ups back then were 964 cams for both normally aspirated motors as well as the 930's!
Count your blessings! At least you can pass emissions without a cat. I am getting ready to pull my headers in the next month or so to install the stock heat exchangers and cat for our emissions test. Since I get free dyno time (lucky me!!!), I am going to try and do a run or two just to see how much power is actually robbed.
My dad is not doing too well and I almost flew up last week to see him, if things don't get better I will be up there sooner rather then later. It might be fun to take an afternoon and help you out a bit and help take my mind off of things. I can help you drink your Sleeman's.
Ralph
Old 02-25-2005, 09:03 PM
Jeff Alton's Avatar
Ralph, Sorry to hear your Dad is not well, my best wishes to you and your family. If you end up comming up, I can always use help drinking the Sleemans, or even a Sonoma Cabernet!
I kinda would like to be forced into a 3.8, but it will be tough to part with the money if the P/C set is ok as it is! Hmmmm..... 3.8....Hmmmmm
Head studs are out- seemed a little to easy. Only took about 40mins.
I am starting to think this motor has been apart before. Just waiting for a couple of tools arrive on Monday and then I will split the case on Tuesday morning.
Tuesday is also the day that the coil overs and 935 front and rear suspension pieces go in!! Yipee! That should be fun. Alignment and corner balance to come. You can't quite see the primered IROC bumpers hanging on the wall, just out of view, but they should also be going on soon!
I am going broke in a hurry!!
Cheers, Jeff
Old 02-25-2005, 09:43 PM
Hi Jeff,
40 minutes for all the head studs. I am having to heat up each one and averaging 10 to 15 minutes for each one. Wade
'72 911 T
Old 02-26-2005, 08:00 AM
Jeff Alton's Avatar
Wade, only two required a little bit of heat, went pretty easy as I have had the touble you are having more than once! Good luck!
Cheers, Jeff
Old 02-26-2005, 09:50 AM
Jeff Alton's Avatar
Okay, Okay, so its been almost two months now but today I finally had time to split the case! Yipee, time to send out the crank and rods...... The heads and P/C set went off the Rennsport yesterday. Cams and rockers are back here already. At this rate I should be done in about another 12 months. Ha!
Here is a couple of pics.
Had to get it off the stand to make room for the 3.2 that gets here next week and the 3.0 that comes in early may. I guess my motor just has to wait!! Oh well.
More to come......
Jeff
Old 04-14-2005, 11:25 PM
